Question about Indesit W 123 Front Load Washer
Indesit WG 635 P
Need to replace program timer, but can't find one
  • 99 Answers
Model no req and product no.
Posted on Oct 11, 2008
I need replacement timer motors for T 103 Intermatic timers.Where can I order them from?
1) Copy fo0llowing links:
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html#clock
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#Hz
2) The suffix, -1 and -3 are not important.
3) WG733 is 208-277 Volt clock motor, normally found on sprinkler timer or T1900 series. WG430 is 120Volt clock motor normally found on T1400 series.
4) T103 timer is stock 120Volts, but can be changed into different voltage timer by changing clock motor.
Jan 21, 2013 | Intermatic Hardware & Accessories
My Indesit washing maching WG 1234 T, just keeps filling up and will not start its wash cycle.
Usually, when water fills up to a desired level, for example: choosing a small, medium, or large load. The floating switch will trigger a signal to turn on the motor to turn to start the agitation. In this case, the floating switch is bad or the floating mechanism is not working. Therefore the machine didn't do anything. It needs to access to inside the back panel to check it out. Cheers.
Aug 13, 2010 | Indesit Washing Machines
Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
May 22, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Indesit wn 1060 wg/1 not emptying
Remove the hoses from the pump and inspect the inlet strainer for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Washing Machines
Indesit washer model number wg 1432 wont spin
Make sure the washer has fully drained, if it has filter, remove and clean, check your user instructions if you are not sure.
If you stillcan't get it to spin after these checks, come back to me.
PLz rate this solyution.
Thanks.
Jan 02, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
I Have an indesit WG 1185 B - WG 1185 - W and a piece of wire has got under the rubber seal and in under the drum. You can hear it scraping along the drum when in use and after using it a couple of times...
The easiest way to remove objects from between the drums is to remove the heating element. To do this remove the backplate from the machine. the element is located on the back of the drum and is rectangular shape with curved corners and will be secured by a single nut in the centre. To remove it unscrew the nut and pull the element out, usually the wire will be wrapped around the element, be careful not to damage the rubber seal and make sure the machine is unplugged before attempting. if you need any more help please let me know.
Thanks,
Nov 24, 2008 | Indesit Washing Machines
Indesit wg 1285w
Replacing the capacitor might solve your problem. Good luck!
Aug 30, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
148 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
