Question about Brother MFC-8840D All-In-One Laser Printer
BROTHER MFC-8840D "Check Scan Lock" error message
I purchased my Brother printer new over 4 years and it's been great. Unfortunately, It recently displayed "Check Scan Lock" message on LCD and the printer will NOT print or scan anything. The scan lock button has never been used until I tried that simple troubleshooting tip and it did not resolve the problem. Is there a solution for a home user besides taking it in to Brother repair shop?
  • Walter Jorgensen Mar 12, 2009
    "Check Scan Lock" appears in the display window but the scan lock is in the OFF position, i.e., w/o the red showing. In fact, the scan lock lever won't slide all the way ON! Of course, the machine will not do either ADF or flatbed scanning. ??????????????????????
    It will, fortunately, still print from the computer.
    Walt Jorgensen
    waltjorgensen@comcast.net
I had the same problem. It means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This may fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remover the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable be carefull not to drop the lid, break the cable or the glass bed. After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp farther into the scanning area and repeat. Good Luck
Posted on Nov 28, 2008
BROTHER DCP 8020 ERROR 6A
A Brother MFC-8840D reported an Error 6A on the panel after a short power-outage that occurred. Calling Brother indicated that the error reflects that.
To clear the error, the procedure is as follows:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
This should clear the error.
Good luck
Please rate FIXYA
Apr 07, 2011 | Brother DCP-8020 Laser Printer
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Does the briothers mfc 8840d scan directly to a pdf
well if you got a software disk from brother when you bought the printer if that has a scaning program o it install the disc on your computer and open it, put the paper on the scanner and view the advanced settings on the scan program if it has any otherwise search the settings and find the extension or format that it saves in and change it to what you prefer
Jul 04, 2010 | Brother MFC 8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Machine error 6a Brother 8840D
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
Nov 16, 2009 | Brother MFC 8840D All-In-One Laser Printer
Black copies and black scan
sounds like you have a CCD problem or possibly a board. CCD stands for charge coupling device and its what interprets your scan original to convert it to digital form. these machines carry a 3 yr warranty. hopefully, its covered still.
hth,
razors
Jan 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
My brother mfc - 8840D will not scan, please help
if it can copy copy correctly then its not the scanner. most likely you do not have the scanner software installed.
Dec 23, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D Service Manual
www.justmanuals.com is a great place to find manuals. Very low cost.
Aug 04, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
2,247 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
