Question about Roper RT14DKX Top Freezer Refrigerator
Refridgerater freezer very cold refridgerater not cold and water at bottom
  • 2 more comments
  • badbrain Oct 14, 2008
    My Roper RT14 does the same thing. The freezer is very cold, the refrigerator is barely cold (with the thermostat at max) and water drips into the frig from above. In my case the freezer door was open for a couple of days which may have started the problem. I removed the frost and the freezer now closes properly. Any ideas how to resolve the frig temp problem?
  • Anonymous Dec 02, 2008
    freezer is working properly, refrigerator thermostat is on max. & not staying cold
  • Anonymous Mar 28, 2009
    I have the same problem. I keep turning the temp knob to different settings but no change.
  • jaimegarza91 Apr 29, 2009
    My refrig. dosen't blow air from freezer to bottom refrig. What could it be?
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Posted on Mar 31, 2009
Amana refridgerater freezer will not keep freezer frozen
this might have something to do with the defrost disk located in the frezzer behind the panel, its a small round disk attached to your coils. get a part or model number and look it up. hope this helps.
Feb 12, 2013 | Amana Refrigerators
Freezer is working but refridgerater is not getting any cold air
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refridgerater won't come down to under 50 degrees
heatman101
Oct 19, 2010 | Amana Refrigerators
The freezer gets cold but the fridge does not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jul 28, 2010 | Dometic RM2652 Refrigerator
My Whirlpool refridgerater on the bottm has stop getting cold, but the freezer on the top is still working perfectly. Could the amount of food in my freezer effect the temperatue of my refridgerater?
highly unlikely u usually have a duct that goes thru from the freezer to the refrigerator make sure this channel is open and not blocked or u have a fan in the refrigerator one of the 2 if u have a fan it will be behind a panel in the back of the refrigerator if u have a fan it may not be running if its not running check voltage and make sure u r getting power to the fan if so then spin the blade and make sure it spins freely if it does then u have a bad motor replace it its very simple and cheap hope this helps
Feb 27, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerater-freezer model#
check relay in compressor. check if compressor is running
Feb 08, 2010 | Refrigerators
Freezer works but no cold air in refridgerater temp in fridge is 60 temp in freezer 20
CHECK THE FREEZER FAN. IT MAY ALSO HAVE A DEFROST PROBLEM, CHECK TO SEE IF THE BACK WALL OF THE FREEZER IS FROSTED UP.
Jan 12, 2010 | Kenmore 56663 Stainless Steel
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | Westinghouse Refrigerators
Roper RT14DKX Top Freezer Refrigerator Logo
214 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
