Question about Smeg Kitchen Ranges
The ignition of my Smeg cooking gas top is constantly on and making a clicking sound. This is happening for all the 4 plates and it has been going on since morning. Please provide a solution. Thanks Manish Nihalani Mobile:0431390877
    President:
  • 1,462 Answers
Try easing up all the knobs a little
Posted on Oct 05, 2008
New smeg gas cook top. flames burn with yellow top
There has to be a small screw close to where the burners are located and all you need to do is turn clockwise half a turn at a time (have the flame/burner on), to adjust the flame . Good luck
Nov 03, 2013 | Kenmore 63942 Dryer
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
SMEG Oven SA9066XS
If this is an Electric over, the heating element is damaged. The device has a open connection. These element break down often. Usually, the manufaction will sell this whole element as one fixture. They are usually easy to replace.
If it is a Gas oven, the polit is out. Sometimes they go out, and its ok to relight them. But this sounds like an Electric over!
Oct 22, 2008 | Smeg Ovens
One cook top is not working
Hi
Even though you do not mention the brand and model of your Gas top, I am pretty sure that, that specific switch is bad.
With more info about the type and model I might be able to help you more.
Eddie Rentas
Tupper Lake NY
Jun 23, 2008 | Smeg 23 in. SE64 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Kitchen Ranges Logo
219 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
