Question about HP LaserJet 4250n Printer
Hp_laserjet_4250n_printer hi, i am having a problem with leser jet 4250. The problem is when i turn on the printer in the control panal it displays 048mb******** such kind of message and all the button are disable how can i solve such a problem? thank you.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Please reseat the memory DIMM of the printer
Then perform cold reset
NOTE: The Jetdirect LAN (such as the IP address of the printer) settings will be reset to defaults by this operation. Record LAN settings before resetting the printer. Reconfigure LAN settings after the reset if you are using a LAN connection). To avoid resetting the LAN settings disable the embedded Jetdirect before performing a Cold Reset by choosing the Disable LAN option from the choices available when you get to step 5 below. Note that after choosing to disable the LAN it is necessary to reboot the printer and then choose to perform the Cold Reset . During the power up sequence only one operation can be performed at a time. In this case, first disable the LAN, then reboot the printer and perform the Cold Reset followed by another reboot to reenable the LAN.
To perform a cold reset:
  1. Turn the printer power off.
  2. Power on the printer and watch for the memory count to begin.
  3. Hold down the SELECT (Checkmark) button, when you see the memory count begin.
  4. Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
  5. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET appears on the display
  6. Press the SELECT (Checkmark) button. The printer performs a cold reset and then continues its power-on sequence.
  7. Check all I/O settings and reset any user-set printer configuration values.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-13
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is 192.168.0.90, type FTP://192.168.0.90.
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Posted on Oct 30, 2008
  • Nikhil Gedam
    Nikhil Gedam Oct 30, 2008
    Let me know once done
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
Sep 29, 2011 | HP LaserJet 4250n Printer
Laserjet 4250 error 59.00
I've found this specific error code leads you to a main motor failure, Ive found some decent priced motors if you need them: HP 4250 Main Motor
Aug 30, 2011 | HP LaserJet 4250n Printer
Geting erro of 59.00 in 4250 printer
hi
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
What are the options on HP laserjet 4250 menu, i want the one to enter IP configuration
Follow these steps
Menu
Configure Device
I/O
Jet Direct Menu
TCPIP
Configuration Method
Oct 25, 2010 | HP LaserJet 4250n Printer
HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
Mar 19, 2009 | HP LaserJet 4250n Printer
Printer problem
First remove the control panel from the machine and make sure that the cable is seated well to the panel and the control board. If they are remove both cable ends and reseat them.
May 21, 2008 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
610 people viewed this question
Seeker5211
Seeker5211
