Question about Velodyne DD-18 Subwoofer
Velodyne ULD-12 driver voice coil sensor availability
Does anyone know if it is possible to get the motion sensor/transducer for the Velodyne ULD-12/15 anywhere?
  • Anonymous Jan 29, 2009
    no chaces ... tryied for f1500 is same sensor...
    darek
    daran59@wp.pl
  • 124 Answers
Contact Velodyne. That is the only source for this part.
Posted on Jan 04, 2009
Very low output and clicking noise. Circuit boards glued in. Company wants $250 to fix. Any other possibilities for rehab?
The amp is clipping.. witch could mean there is a bad or lose ground, or wire are lose on speaker or worst you voice coil is melted.
good luck home this helps
Sep 11, 2015 | Velodyne DLS4000R Subwoofer Speaker
The bass of my wowee one doesn't work anymore
The problem is most likely a broken solder connection on the the voice coil side of the bass transducer. I just repaired one and it was a 5 minute fix if you have a small soldering iron. Carefully pry off the glossy plastic cover where starting with the side the speaker slits (grill) are. It's just held in with some sticky adhesive (peel it up slowly, allowing the glue to separate without cracking the cover). Below that cover are 6 phillips screws. Unplug bass transducer's wire harness from the circuit board. IThe white connector comes apart with a small tug. The other end of the wire harness goes to the round, green transducer's board which contains the voice coil. Remove the transducer assembly (the round thing with with the clear Gel like substance). Carefully remove the gel surround and separate the round circuit board from the round magnet. One of the black or red wires will probably be disconnected. This is probably due to the a bad solder connection coupled with the constant vibrations. Simply re-solder the connection and re-assemble and you're good to go. When re-asembling the transducer, be sure to install the round board first and make sure it slips UNDER the raised lip inside of the Gel. If installed correctly the whole bottom of the round green board will be in full contact to the gel. Now install the magnet. The magnet should rest on TOP of the gel lip inside, the lip keeps the magnet raised slightly above the board and allows it to vibrate freely without touching the the round board and the voice coil (brown colored wire winding attached to green board. Hope this helps.
Mar 22, 2012 | Audio Players & Recorders
I have velodyne hgs15bg powered sub.. After a prolonged hard run, it developed a rattle at mid to higher volumes. what went wrong ??
You possibly ripped the woofer cone or welded the voice coil - something mechanical. There's only one thing in there that moves on purpose.
Mar 03, 2011 | Velodyne HGS-15 Subwoofer
My subwoofer keeps poping and then stops working
larryagross,
Sounds like you blew the speaker! The amp is sensing the voice coil is connecting to the speakers magnet or iron core and is going into a safe mode. It is possible to blow the coil even when the sub has a built in amp.
First make sure that you have the gains properly set ans not all set to their maximums. Second, disconnect signal to the sub then unplug the power for a few minutes. Third, plug the sub into a source of power on a different circuit using a surge protector.
Does the speaker make any popping at the time it powers up? If so you have a amp problem. If there is no sound produced, connect it back the the system using a different signal cable. Does the speaker now pop again when sound is produced. If so the speaker has failed. Contact a Velodyne repair facility.
-Chris
Aug 10, 2010 | Velodyne CT-80 Subwoofer
Velodyne model spl88v will only make a high pitch chirp used to only happen at turn on now wont play
Could be one of two things.
The speaker could have a rubbing voice coil, that was the "chirp" sound
Over time, this will damage the speaker. If it shorted, then it may have blown a fuse in the amplifier section.
Any good electronics shop should be able to fix this for a reasonable cost. You also could try the place you purchased the unit from.
You could also contact Velodyne.
Nov 19, 2009 | Velodyne SPL-800 Subwoofer
I have a Velodyne fsx-12 subwoofer. Problem is
Velodyne is the only source for parts and service on this unit.
You will need to contact Velodyne
Sep 18, 2009 | Velodyne FSX-12 Speaker
Extreme distortion with Velodyne SPL 800II
Woofers are subjected to relatively high degrees of acceleration which can cause a poorly built voice coil or spider (an additional support located at the junction of voice coil and cone) to break away from the cone or the surround at the edges of the cone may have dissolved. Cigarette smoke is death to the common foam-type suround and once it is no longer intact, the cone can slap on the frame edges.
Only the very expensive band/concert-type speakers are worth repairing. Check on eBay for the right size replacement; they atart below $20 US.
High quality speakers actually come with a warranty but then, the Chinese company that built them may not outlast the warranty.
Apr 27, 2009 | Velodyne SPL-800 Subwoofer
Velodyne subwoofer HGS12
Not able to help you in Brazil
Contact Velodyne via their web site
Jan 15, 2009 | Velodyne HGS-12 Subwoofer
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
Velodyne Hgs- 15x
The driver has a soft foam rubber gasket behind it. It can act like glue on the driver.
Taking the driver out will tear up this gasket, always does, so don't worry about that.
You can try to lever the driver out. Use care not to scratch the baffle.
Apr 08, 2008 | Velodyne CHT-12 Subwoofer
Velodyne DD-18 Subwoofer Logo
330 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
