Question about Microwave Ovens
How to get rid of H97
H97 is displayed and wont work
  • Anonymous Mar 12, 2009
    Same problem - 5 months old & H97 fault..... are these Panasonic Microwaves worth .......anything?????.............
I have had this problem with the same Panasonic! Then after replacement with same model...
happened again!!!!!!!!!!!!!!!
No...Panasonic microwaves are worthless.
Posted on Aug 24, 2010
H 97 is an inverter or magnetron fault you will need an engineer to fix try 08705 678910 for help,dont try to repair yourself risk of shock stored energy.
Posted on Oct 05, 2008
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: h97
H97 is a problem with the inverter, bad magnetron or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
H97 DISPLAY APPEAR
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Jun 05, 2015 | Panasonic Microwave Ovens
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Panasonic flatbed microwave NN-sf550W displays code H97
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jan 21, 2013 | Microwave Ovens
In the display there is H97
H97 means the magnetron and/or invertor board is faulty.
Call a Panasonic registered domestic appliance engineer for service.
There are no user serviceable parts inside your machine.
Mar 29, 2011 | Panasonic NNCF768M Microwave Oven
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Why doesnt my oven work?
H97 can mean that there is a problem with the Inverter Board, and you may need to take it to your local Panasonic repairer for assessment.
Mar 24, 2009 | Panasonic Microwave Ovens
Panasonic microwave Genius Sensor 1250 W
Jul 09, 2008 | Microwave Ovens
H97
Dec 13, 2007 | Panasonic NN-S953 Microwave Oven
Microwave Ovens Logo
1,152 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
