Question about Dell Inspiron E1705 Notebook
How do i use my built in wireless connection to connect to the internet,please.
Hi.
I have a Dell Inspiron 6000 lap top and it has a built in wireless connection.
How do i connect to the internet wireless ,please ?
Many thanks.
  • Anonymous Feb 01, 2009
    I have to place my dell Inspiron E1705 beside my belkin wireless G plus router to connect to the internet. However, I have another laptop that will connect from a good distance away. Not sure what the problem is?
  • 282 Answers
Make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Posted on Oct 05, 2008
SOURCE:
Hi I have a Dell inspiron 5100 lap top. I have
  1. Right click my computer
  2. go to properties
  3. device manager
  4. you will see network adapter and under that will be wireless adapter
  5. click on wireless adapter
  6. go to properties
  7. See if device is working properl
Dec 02, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
I have a dell inspiron 6000 lap top I cannot
Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The "Dell PC Restore by Symantec" window will appear. Click "Restore."
Just make sure you have saved all your data before doing that.
Oct 29, 2009 | Dell Inspiron 6000 Notebook
My inspiron 6000 will connect to my wireless
Several resoning behind this one. One check your firewall setting, and make sure your wireless card have permission. Two, make sure that your mac filtering is turn off. Your wirless network has it own mac address and it is not in the router as to be aloud, it will block it. Three if your wireless network has a password, make sure you enter in right, it is case sensative. Four make certain that you have your wireless device is connected to the modem, or modem wireless combine. Finally, if you were running wired, try to clean the temperary ineternet filess off.
Aug 09, 2009 | Dell Inspiron 6000 Notebook
Just put a new hard drive in my Dell Inspiron 6000 laptop. I get an excellent signal when connecting to the wireless router, but I get a limited or no connectivity error and cannot access the internet on...
is it only in one location or everywhere, if only at home reset wireless router. if evrywhere, then uninstall wireless driver and llet windows reinstall it by rebooting
Jun 19, 2009 | Dell Inspiron 6000 Notebook
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 i cant get the red X off the wireless icon?
If you're using wireless internet and should be connected, you'll have to make sure that you're in range of the wireless network and have the proper network key if it's required.
If you're not using the wireless internet and just want the notification to go away, you can double click on the icon itself, and then select 'properties' in the next window that opens. Then just remove the checkmark next to 'notifiy me with this connection has limited or no connectivity'
May 08, 2009 | Dell Inspiron 6000 Notebook
Wireless connection
hi,
welcome to fixya.com
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
My wireless internet isn't working on my Dell Inspiron 6000.
try launching An Internet Explorer, Or web-browser Page.
Also You could look in the device manager, for any problem-devices. Then check that you are getting A receive as well as Transmit signal. ( bytes sent/received ) Check settings In Internet Connectivity.
Mike @ compurepair.
Jan 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
funny what is virgin is it virginmobile ? cellphone ? you need usb cable to pc from cell. also its nto a router thats built in its a wireless card for 802.11g not for cellphone companies.
Oct 05, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron E1705 Notebook Logo
1,476 people viewed this question
Clive
Clive
Alun Cox
