Toshiba Laptop P105 screen has one vertical line of what appears to be dead pixels and also has several small blanked out areas. External monitor works perfectly.
  • 282 Answers
Since external monitor works fine,its not a video card or mother board problem,lcd should be replaced..
Posted on Oct 05, 2008
Vertical lines appear on my screen on my toshiba sattelite p105-s6147 laptop computer.
looks like the pixels are going try anther screen it should work ok
Jan 08, 2013 | Computers & Internet
Monitor has a vertical line through it
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Dec 29, 2010 | Toshiba Satellite P105-S6024 Notebook
Display Problem - with vertical regulaqr line
I would connect your laptop to an external monitor first of all.
That will rule out laptop Motherboard problems. If it shows a good picture on an external display, a new screen will be required.
Spares can be found at
Hope that helps.
Nov 29, 2010 | Toshiba Satellite P105-S6104 Notebook
I have vertical lines (15 of them now) on my Toshiba laptop.
I'm afraid when you see vertical line on an lcd panel, it most likely is screen failure. Ebay has plenty of screen from good companies in Texas. I get most of my screens from Ebay store LCDTECH99. They have the best prices, most screens are under 100 bucks and they ship right away. The Toshiba screen is an easy repair, Only the bezel needs to be removed in most cases. Below is a guide to show the process.
Nov 27, 2009 | Toshiba Satellite P105-S6227 Notebook
Vertical lines on laptop monitor
This would need a screen replacement
Lots of people do this themselves
Ebay is a good source for laptop parts most of which are NEW
Aug 26, 2009 | Computers & Internet
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
My Ibm Laptop r51 has a vertical lines on the screen
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly: has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 02, 2009 | IBM ThinkPad R51 Notebook
Pink vertical line
From what you discribe it sounds like you have a row of dead pixels.
You can use this website to test for dead pixels:
If you run the test and confirm that you have dead pixels, contact the laptop's manufacturer for support.
May 19, 2009 | Toshiba Satellite P105-S6177 Notebook
Vertical lines on screen
Everything can be fixed.
Try hooking up your laptop to an external monitor. If you get lines then the problem is the video card.
If not, it's the lcd, usually it is anyways.
Just replace the lcd and your problem is gone.
Best of luck!
Feb 25, 2009 | Toshiba Satellite P105-S6207 Laptop
Laptop screen issues
This is a bad pixel sensor. Your screen has hundreds of vertical and horizontal pixel sensors on the edge, if one goes out on either end it causes a dead pixel line through the screen. Unfortunately, the only way to fix it is to replace the screen. If you can live with the annoyance, I've seen screens last for years with a pixel line without any other problems.
Jul 15, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
