Question about Janome Sewing Machines
Problem with upper tension on Janome MC11000
Though the Janome MC11000 features auto-tension, it can be adjusted.
Thing is, mine is trying to adjust, I can hear it working . . . but when I lower the presser foot there is still not sufficient tension to maintain proper embroidery (lots of loops on the bottom).
I see there is an upper tension adjustment screw when I open the door of the machine above the needle) but the adjustment doesn't seem to want to hold for some reason.
I am in a small town and the nearest dealer is someone I will NEVER go to again (he had me making 5 trips over a sensor he claimed didn't exist, it was a real nightmare and ended up having to ship the machine back to Janome, who were able to repair that particular issue).
So . . . the nearest dealer for me is in California now (next state over for me). Can anyone give me any advice on how to fix this issue myself? I have some transportation issues just now (it's out of warranty anyway) and I really need this machine to do my digitizing tests on.
Everything else seems functional but this is enough considering how important the tension is (it is definitely the upper tension - I have determined this with extensive testing).
Thanks for any help offered. Replies can be sent to
SOURCE: Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
Posted on Aug 24, 2008
SOURCE: Embroidery mode
Had machine repaired $95.00.
Posted on Sep 01, 2008
SOURCE: adjusting timing on brother pe 150 embroidery machine
How do I adjust the timing on my machine?
Posted on Oct 04, 2008
  • 1388 Answers
SOURCE: janome 9500 bobbin tension too tight can I adjust it
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really .....actually .....need adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do is,
and eventually, you do get a "feel" for the correct tension and then it happens quite a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on May 01, 2009
  • 161 Answers
SOURCE: lost embrordry presser foot
If you haven't already solved this problem, they are easy to get from a janome dealer
Posted on Sep 11, 2010
I have a Janome Horison Memory Craft 8900 SpEd, thread looping on backing side for free motion. DO i NEED Part No. 200-445-007 Janome Bobbin Holder for Free Quilting and Hand-Look Quilt Stitch.
Free motion quilting is a finicky function, much more than most other sewing. Since you are getting loops on the back of the fabric, try increasing the upper thread tension. Tension causes the top and bobbin threads to pull against each other. If the pull is not equal, the threads will be pulled to one side or the other.
If you continue to experience looping under the fabric, it could be that the top thread is not fully seated in the tension disk. Try this:
Remove the top thread completely from the machine.
Be sure to install a brand new sharp needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Retest your machine.
However, if you don't find a fix, $25 for the special bobbin holder is probably a reasonable cost if it takes care of the problem. The reviews seem to be good:
"Yesterday I bought a new free motion quilting foot and a bobbinholder (for free motion) for my MC Janome 6600P. I have been quilting all day, and belive you me it is a greate investment!!! :lol: :lol: Its like sewing on butter :lol: :shock:
Free motion Quilting Foot: part no.: 200-442-004 (MC6600P and MC11000)
Bobbin Holder (for free quilting and hand-look quiltstitch): part no.: 200-445-007 (MC 6600P, MC11000 and MC6500)
Bet you would love to have those too if you are doing a lot of free motion! The quiltfoot you can adjust so it works perfectly on your quilt!
:lol: :D :wink: I am sooooo happy!!!!"
LOOPS Tension or Speed
Free Motion Quilting Tension Problems
Mar 01, 2018 | Janome Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
Stitching not good, needs to get the right tension
I've found it takes some trial and error to get the top and bottom threads balanced, I keep practicing on a scrap until it suits me. There's a tiny screw on the bobbin case that can be loosened/tightened the tiniest bit at a time if adjusting the top tension dial doesn't fix it. I usually have to run mine at a lower number than what is in the center of the dial (considered normal I guess) Good luck!
Jan 26, 2015 | Janome Sewing Machines
I am using upholstery thread in my Janome HD1000 and it jams
Jan 17, 2015 | Janome Sewing Machines
Need to update software from 10000 to 11000
Memory Craft 11000
Version 2.10 update is available for owners of MC11000 Version 2.01 and MC11000 Special Edition. Version 3.10 update is available for owners of MC11000 Version 3.00 and MC11000SE Version 3.00 with the purchased Professional Quilting Kit Version 3.00. This is not the update program for the owner of MC11000 Version 1.31 or earlier.
Oct 19, 2014 | Janome Memory Craft 10000
Advice on how do I adjust tension
I don't have a Janome, but in general
if your seam has extra loops at the top
looks like ^-^-^-^
loosen the upper tension a bit and tighten the bobbin tension a bit.
If the extra loops are at the bottom
sort of like \/-\/-\/-
do the opposite - tighten the upper tension a bit and loosen the bobbin tension a bit.
The upper tension is easy; it's usually a dial with +/- numbers. The bobbin may be more difficult. For mine, it's a screw on the side of the bobbin case. A web search seems to indicate Janome is the same.
Practice on scraps of the same weight and use the same thread you're using on your project until you get the tension right.
good luck
Oct 03, 2014 | Janome Sewing Machines
How to open front of janome 8050
You typically don't need to remove panels to clean the upper tension. Just take some un-waxed dental floss and run it through the tension area a good few times while the pressure foot is in the UP position..
Remember one thing about these "computerized sewing machines" Computers are DC power... otherwise known as "Direct Current" but more memorable because DC is also the "DEATH CURRENT."
Jul 22, 2012 | Janome Sewing Machines
Sewing Machines Logo
71 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
