Question about Fujitsu LifeBook A6110 Notebook
Wireless notebook wont connect to the modem!
Talked to msn tech support they said it was a setting in the notebook itself, not the modem, or the connection. Its only 3 months old. also, when I hook the Ethernet cord to i,t the lite on the modem Doesnt come on!
Pls. help
.Thanx Ms. EDO
Wireless wont stay connected have to manually connect
As you move about? Or just sitting next to it? You can start by unplugging the ISP modem , remove battery, if applicable, Unplug the Wireless. Check ALL cables and connections, reseat ALL connections to the ISP modem and Wireless. Replace battery in the ISP modem, plug in, wait from the modem to selftest, plug in the wireless device, wait fro selftest, reboot computer, re-connect to wireless. Any change? If no , contact your ISP to test the signal, have a ISP tech come to analyze the signal, it may be a outside equipment issue.
Jan 13, 2013 | Dell Inspiron Mini 10 Notebook
Cn6555, cannot connect to internet via wireless, modem, can w/lan
Its not your Notebook problem but it is just a setting problem. You haven't make any setting but the operating system are having certain default setting as per the need (i.e. for dialing rule it would be set some local number in which region you have default apply during installing of os, etc) Just contact your service provider for support and setting. While if you want to access the wireless network just switch on your wireless network adapter then go to network and sharing center and in that you will find connect or disconnect option. Just click it and you will be get all the available connection. Choose your network type and click connect. That's it.
May 17, 2010 | Balance CN6555 Notebook
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Wireless will not work in my panasonic cf50 after running restore
You need to download the driver in order to get it to work. Suggestions are using the ethernet connection if possible, or by whatever other means you used to post this message and download the driver for the wireless network card. If you used a secondary computer to download the driver, use a jump-drive/pen drive/thumb drive/memory card/etc, to transfer to this computer.
Jan 10, 2010 | Panasonic Toughbook 50 Notebook
Can't get my di-524 router to work
no a straight cable...you are going to need to clone your MAC address on your router so that your ISP can see it.. email me at techray1@live.com
Jun 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Dell Studio 1735 off line-won't connect to Internt today
to verify, turn off trend micro then try going online.
May 08, 2009 | Dell Latitude 110L Notebook
2wire modem keeps on disconnecting
looks ur internet setting is not right on ur new laptop for the modem u are using....call ur internet provider and ask them for technical advise and help
Apr 19, 2009 | HP Compaq Presario CQ60Z Notebook
Wireless phone connects and then drops.
I switched to a qwest modem and a lynksys router. Works flawlessly now.
Feb 04, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
Wireless connection
that unit has a driver problem, for the usb or ethernet, you might be able to re-install the specific drivers on their web site, and retry it there, unless the wireless in pci based and the you have a driver problem there, if you can use the ethernet connection then it's usb or pcmci, try that, if that doesn't work you need a tech to look at it.
hope this helps you out, let me know
Jun 15, 2008 | Acer TravelMate 2300 Notebook
Fujitsu LifeBook A6110 Notebook Logo
852 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
