Question about Philips GOGEAR SA6045 MP3 Player
Playlists I have an SA33xx (it wasn't listed and the SA6045 was the closest) I want to add playlists that are currently on Windows media on my computer. How can this be done, I have tried to just sync them but they don't show on the mp3. Can anyone help?
  • 8,596 Answers
The SA33xx series does not support playlist transfer. You can create a Playlist on the Go as the manual suggests, but it will not allow you to transfer your own playlists.
Posted on Jan 01, 2009
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
28
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
This mp3 wont format a play list
For the MP-610 you can make playlists using Coby Media Manager.
In Coby Media Manager there's a help section that gives next information how to make playlists:
You can create playlists to group songs (example “My favorite songs”).
To create a playlist, right click in the Playlists section (located on the left side of your Coby Media Manager window), and choose Add. A playlist is created. You can rename it using the F2 keyboard key.
For Coby Media Manager download, go to next site:
http://www.cobyusa.com/?p=fix_mp822
Install the software as told and when running the Manager for the first
time go to the page top: Tools > Device Manager..
Select your player from the Devices List, this software can be used for.
Add the device, AC or AL version. Finally enter OK under the Favorite Devices list.
All support for the MP610:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
If this was helpful, I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Coby MP-610 MP3 Player
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
Playlists
you can add it by connecting your device to the pc, open either real player or windows media player and there is an option in both the softwares to synchronize the device to pc. after synchronizing, add them to your device. the playlists you created in your pc will be exactly in your device then
Aug 29, 2009 | Philips GoGear SA5285/37 Digital Media...
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Custom playlists
3346 automatically changes the playlist to alphabetical format - sorry
Mar 04, 2008 | Philips GOGEAR SA6045 MP3 Player
How to create multiple playslists for M250
Alright, well if you are adding songs to your MP3 player by using Windows Media Player, you can create playlists there, sort the songs into what playlists you want them in, right click the playlist, and click "add to sync list".
If you are manually copying and pasting the music into the mp3 player (that's how I do it) it's a little less obvious... For me there are three main folders: Music, Playlists, and RECORD. So we want to go to the playlists folder. In there, assuming you have at least one playlist already, you can copy and paste it, naming it something else and changing its properties as you see fit (right click -> properties). To add songs to the playlist, you go to it's properties, and under the references tab, drag the music files from wherever you have them stored and drop them in the references tab. This won't move your music, it'll just add them to the playlist. and.... guess that's about it. Hopefully that helped.
Feb 24, 2007 | SanDisk Sansa m250 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
120 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
