Won't start. no indications of power when ignition key turned on.
SOURCE: key stuck in ignition but it will turn, and
you most likely have a bad key switch cylinder assembly. you can try to spray wd40 solvent into the switch before you have the switch replaced,but sometimes it's a switch replacement that repairs the problem. have you inspected your ignition key to look for damage to the key itself? try a spare key to make sure it's the key,and not the key switch. you can also try turning the key while turning the steering wheel at the same time to get the key to work.sometimes the switch locks when parked in a bind,such as on a hill,or against a curb and so on. try this 1st before you have the ignition switch replaced. AAA auto club,if you're a member covers part of the replacement costs for a replacement switch also. you may have coverage through a cell phone also.one more thing to try, if you have a tilt steering column,try to reposition the steering wheel to see if you can get the key to turn. remember never force it enough to break your key off into the switch! thank you for choosing fixya.com!
SOURCE: My car won't start I
The key barrel is defective and it will haver to be replaced. Since you will have to force it to make it turn long enough to get it out you should take the car to a repair shop - the risk of breaking something is too great for you to do it.
SOURCE: Trunk lid won't electrically open
Its possible that your problem isnt electricla, maybe mechanical (physical); check the next procedure about Trunk Lid Lock Cylinder REMOVAL & INSTALLATION to confirm and adjust...
Fig. 1: Pull the trunk lid lock cable upward from the bracket and slide it out of the lock cylinder plate
Fig. 2: Pull the lock cylinder retaining clip upward
Add WD40 oil to lubricate all components; about the fuses, you are right, isnt showed in the manual, but could test and check position 25 and 30 in passneger fuse panel (alarm and locking system).
Keep us updated.
SOURCE: 2001 honda crv I'm driving
Sounds like you need a new ignition. If its really stuck you will have to get a replacement key and a new ignition. Usually not to expensive and any competant shop can swap it for you. You also might want to check the neutral safety switch. That is the only switch that has to do with your drive park position.
1996 gulfstream scenic cruiser on spartan pusher diesel chassis. Batteries are good. would like to get a schematic for the relay box on front left corner of coach.
