Question about Intertherm Heating & Cooling
Intertherm G4RK096C-16 Gas Furnace Fan not cutting in during heating cycle. If we wiggle the wires, fan cuts in. Some time ago during servicing, a variable speed control for the fan was installed. There is now a red wire going to the fan connector on the control panel and a blue wire with a spade tip is taped off. If we were to disconnect the variable speed control, which wire (red or blue) should be connected to the connector on the control panel?
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
  • 30 Answers
SOURCE: Is there an easy way
I have never heard of a variable speed Intertherm. If it has multiple wires it is likely just an adjustable fan where you can use a different lead for a different speed. Usually black is high blue is med. hi, red is low, ect. Check your wiring diagram on the furnace door. Why do you want to change the speed?
Posted on Nov 24, 2008
  • 85 Answers
SOURCE: I have a Carrier weathermaker
Go ahead, just turn off power to breaker box first, or you'll be cursing for at least 10 minutes...
Posted on Dec 04, 2008
james3751
  • 614 Answers
SOURCE: Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Posted on Jul 24, 2009
Trouble shoot Dayton gas furnace model GG9S100C16MP11A fan is left on constant but in cold weather 10 or colder fan will go off and furnace will go thru a restart mode and run fine for awhile then will do...
Do not run contentiously during heat mode. the fan runs at a slower speed with heat and heat fires first then the fan cycles on during heat cycle then when heat satisfies the thermostat the heat will cycle off and fan will run for a couple more minutes and then cycle off. So set stat on fan cycle to auto.
Feb 03, 2015 | Dayton Gas Furnace Heater
Intertherm Furnace Model #mmhb070abhr06. Burner lights up but shuts down after about 10-30 seconds then recycles over & over again when fan is set to auto (because fan does not cycle on when set to...
Sounds to me like it is going off on a weak high limit switch. With the fan on it will prolong the event but will not stop it. I would check all of the high limit switches. It would most likely be one close to the heat exchanger.
Apr 06, 2014 | Intertherm 56000 Btu Gas Furnace
After preheat the fan cuts in for 10 sec then cuts out, cuts in for 15 sec, then cuts out. this continues to longer interviles. I have replaced computer box twice and have spent hundreds and problem
Try Googling the problem. Who have you paid so far, someone from the gas company, or a private technician? Was the technician from an Intertherm dealer? I would think a dealer would have qualified techs.
Nov 26, 2013 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Intertherm Furnace - Blower cycles on and off (varies in length)
Its still hard to say from your info...does it seem that the furnace is running a normal cycle except for the fan???...could be a wiring problem , circuit board/relay problem , or fan control problem....really the make and model of the furnace and age would help ....could be several things....does it heat your house to the correct setting??
Oct 29, 2009 | Heating & Cooling
Intertherm furnace model MGHA070AAFC-01 cuts on and off
I assume this is a gas furnace? If so its most likely your fan switch. This is set to come on after the "Chill" is gone on the furnace and go off a few moments after the flame cuts off. there are several different kinds but you will find it if you trace the wiring from the fan motor (usually the colored wire red, blue, or yellow and NOT the black or white or brown) goes to it. If the colors are hard to see use a good lite and some alcohol to clean them up some.
Hope this helps and please rate me accordingly Good Luck.
Mar 11, 2009 | Intertherm P3RA-048K Air Conditioner
Fan cuts on and off repeatedly when heater is on
either the circuit board or the relay that controls the fan in heating is dropping the fan out. it probably uses a different blower speed for cooling than for heating.. you'll need a meter to check if it is losing power.
Please rate this it matters to fixya.
Jan 15, 2009 | Intertherm P3RA-048K Air Conditioner
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Moter will not cut off
is the thermostat set on fan on? Be sure the thermostat fan switch is all the way in the auto position..If you have a circuit board with a g terminal that is a gas furnace. Turn power off remove and isolate the green wire then turn power on. Let me know if it still runs. If it does not the circuit board is the most reasonable problem
Nov 14, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
