Front speakers work fine ---fader was checked ---wondering if in head unit output of amp? did not disassemble doors yet, figuring both speakers blown at the same time?
Check the round multiple connector doors to door post. The connections are very likely corroded and green. They carry all the door electrics including speakers. Use your favourite method for cleaning them as I have no preferred solution. The speaker voltages are very prone to this area.
Best is to check the speakers using a AA cell, if this is OK then the power to the preamp and the power amplifier. You might need to have a signal test using a audio signal injection to confirm the case of the faulty audio stage.
Hi Donald,
Thanks for your Input --I have head unit out of dash ---I don't have a wiring diagram for this vehicle ---I only wanted to take the door panels off If I HAD to. Any other wiring colors that would be for rear speakers that i could check at the back of head unit harness for output or hook external speakers to --so i can see if they work?
