Question about Rosewill R900J 19" Flat Panel LCD Monitor
Weird LCD Monitor problem with screening not turning on.
I have had an Acer 1913W for a few years and when I first got it, I had to send it to get the inverter fixed. It's worked fine since then.
A few days ago I cleaned the monitor through the vents with a really powerful jet of air (don't know it's the cause or a coincidence) and now if I leave the monitor off for a few hours, it won't go back on. It sort of stutters to go on and then goes black but I can still see the image with a flash light. If I turn it off and on a few times, it will eventually light up and will stay working.
Could I have knocked something loose inside with the air? Any ideas what to check inside to see if something needs to be replaced or fixed?
    Top Expert:
  • Rosewill Master
  • 44,045 Answers
Could I have knocked something loose inside with the air? Quite likely
Posted on Mar 28, 2017
  • 163 Answers
SOURCE: Dell flat monitor E197FPf
This model has 4 CCFl's and one of these bad will cause the inverter output to drop off.. (Safety feature).. easiest way to check is by process of elimination plugging a good CCFL from a laptop screen or similar inplace of the 4 to find the one dropping out. If all check good Check the Caps as these like to fail as well. Good luck!
Posted on Jan 29, 2008
SOURCE: Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Posted on Dec 05, 2008
SOURCE: Monitor image comes up, then blacks out, power still on
Hello David,
This is very common problem and is heat/age related, but It can happen to monitors that are no more than a year old. It is usually bad capacitors on on power inverter board. I just fixed two monitors with this problem. This problem is common across all brands. Look for several radial capacitors in a cluster on the power inverter board. If some are bulging or have a slightly domed top, they are the ones that are bad. I usually replace all the capacitors in this small cluster because some may be marginal. This is easy to do if you have a bit of electronics skill.
Posted on Dec 27, 2008
  • 17 Answers
SOURCE: AOC LCD LM725 monitor - Black Screen
OK WELL DID YOU UNPLUG IT FOR A LIL WHILE? IF NOT DO SO. IF PROBLEM STILL THERE HOOK IT TO A DIFFERENT CPU AFTER ALL IS DONE HIT ME BACK
Posted on Apr 21, 2009
  • 251 Answers
SOURCE: Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Posted on Nov 17, 2009
Testimonial: "Thank you."
My acer monitor is under a year old,and now when u turn it on it flashes for a few seconds then it goes blank..
Hello. It is possible that one of the lamps that illuminate the screen is damaged, or may be .. something else. must be brought into service.
Feb 03, 2011 | Acer AL1912 19" LCD Monitor
I have v193w acer desktop lcd screen suddenly it went black the blue light (( which mean that it's on and every thing works fine )) is on all the time but nothing appeared like the the screen is completly...
Ive had that problem recent, same monitor. Same months to be exact, though started around October 2010 then got worse. Do not send it back to Acer, I did and the cost was 20 bucks to ship to them and all I got was a note and monitor back saying they tested and then did Extended testing and found nothing. Not even had it for 1 year or 2 years to say, 3 year warranty. Just going to buy a new one and perhaps a LED from ASUS, the V stands for Value on Acer website, guess I got what I payed for. Think it was $166 I payed for this thing. It is shame, as its nice monitor but I cannot have it not trusty like this, cannot even play some games without it going off like this. Worst if I put the monitor in Graphics or Movie mode makes it worse it seems.
Nov 04, 2010 | Acer V193w LCD Monitor
The screen seems to be slowly turning white.
More than likely a manufacture defect. If it is not that old; I suggest contacting the manufacturer to get it replaced. Most LCD"s have 1 year warranty, and it's certainly, not weird to see 3 years.
Jul 24, 2010 | BenQ FP71E 17" LCD Monitor
SCREEN GOES BLACK AFTER A FEW SECONDS AFTER TURNING MONITOR ON.
More often then not, this is attributed to a failing Backlight Inverter. A Backlight Inverter, is a power board mounted below the screen that actually send power to the Lamp inside the LCD itself. Check to see, when it goes out if there isn't still some images faint in the screen. If this is the case take it to a local repair shop and have them order one and replace it. repair cost for this shuold be around 65-100 dollars.
If this helps, please rate my solution. Have a great day.
May 16, 2009 | Acer AL1715 17" LCD Monitor
Wired Montor Problem
If the external monitor works fine then it is NOT a software problem.
Jan 19, 2009 | Acer Aspire 5920-6727 Notebook
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
ACER AL1716 acting up BAD!
Be more specific. I guess your monitor has inbuilt speakers which are making noise. If yes do come back for a solution.
Sep 30, 2007 | Acer AL1716 17" LCD Monitor
Acer AL2416 LCD
About a year ago I encountered the same problem with an LCD flat screen. It turned out to be a bad driver board but the customer did not want to spend the money to repair it. A good computer repair shop should be able to fix it for you. www.fixmymonitor.com would be a good place to start.
Jun 22, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
