Question about Acer Computers & Internet
Internet will not go on. And all connections are funtioning properly.
    Guru:
  • 558 Answers
It might be the problem with the Lan Card if a Broad-band connection is used.
Or if a modem is used. Check out the Device manager if not showing any flag.
Also try the latest Google Chrome Web Browser, if all Ok. Let me know if you need any assistance.
Posted on Oct 05, 2008
Not funtion
Check you have it plugged into your computers USB port.
Check you have an Internet connection.
If you have done this it should start up and show an magicjack icon on the screen.
If not talk to customer service on
International VoIP Phone Service Customer Care Support magicJack
Feb 06, 2014 | magicjack.com
2003 saturn vue driver window doesn't go up and down . The regulater and motor funtion properly . All other windows work correctly . The console switch on the left side is for both left sides wind
BY PASS SWITCH BY RUNNING A FUSED JUMPER WIRE FROM THE BATTERY POSITIVE TERMINAL TO WINDOW MOTOR CONNECTOR, HOT SIDE, AND A NEGATIVE WIRE BACK TO BATTERY NEGATIVE TERMINAL...IF WINDOW OPERATES....IT IS THE SWITCH
Feb 22, 2013 | 2000 Saturn SL
No image just light
double check your connections and which source you are connected to.
Does the original source funtion properly?
What is the original source?
If laptop, check display options for the video output.
Feb 12, 2013 | NEC LT380 LCD Projector
I can not get into internet
try this codes
06509,
22525, or 2078.
go to the following website if the codes i gave you didn't work.
http://wii.marcansoft.com/parental.psp
Cheers
Jan 23, 2010 | Nintendo Wii Console
My motherboard not responding not making any sound at all
Check to make sure the power supply is fully functional, make sure all connections and memory / CPU is seated properly.
Check to make sure CPU is funtional. Bad CPU bad Bios flash is usualy the culprit with dead motherboards
Nov 03, 2009 | Intel Motherboard
My T12404R's flywheel has stopped turning. it sounds like it is on and manual controls work but the clock is not turning.
I determined that the electric motors had stopped funtioning and ordered replacements. I had narrowed the problem down to either mecahanical or electrical. Both motors were getting powers so I determined that the motors had ceased to funtion properly, probably stripped gears.
Oct 25, 2009 | Intermatic Timer T12404R Pool & Spa...
Wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
May 28, 2009 | Gateway M305CRV Notebook
The whole right side of the calculator only divides and doesn't perform the correct funtion
Batteries or solar cell dead on these TI's
Come cheap nowadays, get a Casio i.e,
Apr 28, 2009 | Texas Instruments TI-84 Plus Silver...
Connection
assuming that all the configuration at wirless accesspoint is ok. see weather the card driver is installed properly. to check go to device manager>network controller> Belkinxxxxx if it is yellow, the might be device is not connected properly or the driver provided to it is not funtioning thanks arun
Jul 19, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
