Pentax Optio A10 Digital Camera Logo
Posted on Oct 05, 2008
Power keeps shutting down.
When i press the power button the Pentax Optio screen appears for a moment while the lens comes out, then screen goes black, and the power shuts off. I was just using it and it was working beautifully.
  • egdirbtcip Nov 16, 2008
    I have the SAME problem with my Pentax Optio M20. It poweres up then about 2 seconds later it shuts down. Replaced with all kinds of new baterries: Lithium, Alkaline , Rechargable Nicads. Still does the same thing. I called the factory. They said to send it in for repair. I thought YEAH RIGHT... The cost will probably be more then replacing this piece of junk.
    Disappointed in Maryland
  • KBball Dec 12, 2008
    I am experiencing the same problem and was also hesitant of sending it in.
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Jun 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
5584
Points
26
It sounds like you may have a bad lens assembly, but you did not mention if it seems to be fully extending or not. If it is sticking, it will usually buzz. If it fails to open all the way, it will turn itself back off. This sounds like what may be happening. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
2answers
Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
1helpful
Pentax optio m20 .. on-off immdly
1helpful
2answers
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
5helpful
2answers
Pentax Optio WP
This suggests the lens motor/gearing has failed- I guess other aspects of the system wait for the lens to extend before coming active - possibly due to the waterproofing system. You can only go back to Pentax with this problem.
1helpful
2answers
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
1helpful
2answers
Freeze Up
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
http://www.badongo.com/file/707791
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
Important!!! Insert a fully charged battery or connect to an external power source.
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware: Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voile...the Secret Menu appears!
Using the down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly! Only thing is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip!
3answers
Power problem with 450
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
