My magnavox 20ms33r keeps turning off the panel lamp stays on but the screen goes off, when I turn the set on then off it comes on for a short time but will not stay on
    Genius:
  • 1,148 Answers
Sounds like 2 me youve got a picture tube probly going bad,, thats usally the case,, good luck
Posted on Oct 05, 2008
Chevy trailblazer problems
its either a bad door switch,or could be the dome override switch by headlight switch,or your interior light switch is all the way up
May 01, 2014 | 2004 Chevrolet TrailBlazer
Have Toshiba 42AV500U that has no back light.
I have an idea that your power supply has failed
Jun 06, 2013 | Toshiba 42AV500U 42 in. LCD HDTV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
I have a kdf-50e2000. when i turn on the power the green light comes on then goes off and red light comes on blinks 3 times on power and screen stays black. changed lamp and reinstalled(just bulb). picture...
Check the lamp door switch. This switch is really cheaply made. The switch is not available. short rhe wires to fix the problem. then never change the lamp witout unplugging the ac power in the future.
Oct 30, 2009 | Televison & Video
Screen come on then goes black
The most common problem. It is related to old backlight lamps. The best solution is to replace them, but if you don't care a lot about total brightness, you may simply replace faulty lamp with 27pF 3kV capacitor, soldered across the high-voltage connector. That would be equivalent load for the inverter.
First of all, you need to find which lamp causes that problem. Disconnect flat cable from the display so all backlight will go through the screen. Now, using that 27pF capacitor replace lamps one by one and check when the light will stay for longer time. Keep that configuration as temporary solution, but make sure you will isolate your capacitor well, 'cause there's about 1000 volts applied to it.
Sep 12, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
CVizio 32" background lamp won't stay on
Ur backlight inverter ic board is dead must be replace.
Aug 31, 2009 | Vizio L32 32 in. LCD HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
May 30, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
