Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Cannot enable wireless function
I tried to enable wireless function under WAN settings on the set-up page but everytime it comes up as an error page.
helpl plz!!!
  • John Hong
    John Hong May 11, 2010
    Could you explain what you did to try to enable wireless and what the error page says?
  • 63 Answers
Enable the wireless fuctionality of the router under the WAN settings using a computer that is wired to the router. You will always get disconnected if you're using a wireless computer to set it up.
If you're already doing it then you may consider upgrading the firmware of the router. the firmware of your router can be downloaded from the manufacturer's support website.
you may consider using a different browser. e.g. mozilla firefox.
Posted on Oct 06, 2008
Trying to set up for first time a TL WR 1043 ND router. Mode 1 : with provided CD Router connected to cable/telephone modem After CD installation and during router configuration verification process the...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Apr 20, 2011 | TP-LINK TL-WR1043ND Router
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
How to install the router
onfigure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
It stopped all of a sudden getting signals from the wireless system from the router and desktop I have in my office.
Reset your router to factory default settings for that press RESET button for 10 seconds it is in back side of router then all settings defaults.Then configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | Compaq Computers & Internet
I brought new wireless router G ADSL2 4 PORT ROUTER but i dont know how to fix
Configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Same problem
Aug 03, 2010 | Computers & Internet
Wireless
http://192.168.15.1
or
http://192.168.2.1
Then click on WAN settings and set wan settings as your internet service provider settings.
Enable DHCP if you want ip from router.
Click on wireless and enable it.
configure it as AP mode access point mode.
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Then save settings and restart router
Jun 21, 2010 | Actiontec GT704WG Wireless Router...
I've just bought a new Belkin Wireless 'N' Router and am having some issues setting it up to the PS3. Everytime I go to wireless settings I go to scan to find the wireless connection but it says access...
On your wireless router , check the wireless settings.
Try to change the wireless channel.
Check if the SSID broadcast is enabled or not. If it is disabled then enable it.
Click Here for more info
Nov 24, 2009 | Belkin Computers & Internet
Router errors
well if you can login to the router, do so and on the first page you come to you will be able to choose your WAN connection... Here's what it should look like..
ad520ba.jpg Secondly, you want to make sure your wireless settings are enabled and correct. This next picture should closely resemble what you see but I cant be sure because I dont know if you have version 1 or 2...
And finally you must make sure your wireless card is set to the correct encryption level to match that of the router... Hope this helps!!
--Joshua79
Apr 05, 2009 | Linksys Wireless-G Broadband Router
Internet Intermittent Drop Out
To isolate the problem beter connect your wireless router directly to the modem and configure it, check if you are able to go online properly so that you can figure out the problem if your wireless router is not working properly, try upgrading the latest firmware and reset the router and reconfigure the router and that will fix your problem...
Oct 22, 2008 | Linksys Wireless-G WRT54G Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
