When i am connecting to the computer external harddisk is in hidden mode how to change the hidden mode
  • Computers & ... Master
  • 709 Answers
It is probably not being assigned a drive letter.
I'm assuming you are running windows ...
Right click on My Computer and select Manage
The Computer Management window will open, select Disk Management
In the panel to the right, find a Disk that does not have a letter associated with it.
Right click on this Disk and select Change Drive letters
Select a letter, only ones not in use are available.
If this is a new hard drive you may have to make it active, partition and format.
Posted on Oct 05, 2008
Windows 7 cant pig up my external hard drive
Try to install the required drivers for the external USB-enclosure. If you did, you should verify if the connections inside the encloser is well connected, as you should also check if the included powersupply (adapter) will be sufficient to power the internal harddisk.
Another test is to connect the drive to a different USB-port at your computer, or,... even better, connect it to a different PC.
Another option is that the harddisk is not formatted. Some OS'es (like Windows) don't handle this well. You can look for Acronis Disk Dokter at Internet, to overcome this.
If all failed, well, then you got an hardware issue. Either the external enclosure is malfunctioning or the harddisk is defective.
Oct 13, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
Lacie drive can't display in my computer
First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
Thanks.
Happy to help you.
Apr 24, 2010 | Microsoft Windows XP Professional
I have an external 500 GB HD. I try to plug it in to my laptop and the light on the front just flashes. The laptop doesn't recognize the HD, and there is no sound coming from the external HD
For that make sure usb cable works fine.
Try with different usb cable.
Also connect usb cable in different usb ports of computer.
Right click on my computer then click on proeperty then hardware->device manager.
Then click on sign of usb controllers then uniunstall all usb drivers 1 by 1.
then restart computer.
Then check.
If still not recognized then when you power up the computer press F8 key then enter in safe mode.
then check.
in normal mode again.sometimes harddisk need to start in safe mode .
Let me know if you need more assistance.
thanks.
Nov 05, 2009 | Western Digital My Book Essential Edition...
I have a eee asus laptop. I cannot startup the window at all. The pc show this message; "Windows could not start because the following file is missing or corrupt C:windowssystem32configsystem " how can i...
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Jul 13, 2009 | ASUS Eee 4G Notebook
New external harddisk cant be detected on my computer
Since you have not given any specifications about model of your HDD hence I'd consider your HDD connects through USB. Your USB driver is old you shall consider upgradation.
Jun 15, 2009 | Western Digital My Book Essential Edition...
My AVG could not scan virus?
if u r computer is full of viruses avg cant work if its is working it will delete the system files. take the harddisk seperately and connect to external harddisk and scan in another computer then put in u r computer it will work
Jan 08, 2009 | Computers & Internet
250gb Maxtor External HardDisk not responding
How are you connecting it to your pc?  are you supplying external power?
Jan 01, 2009 | Maxtor Hard Drive
Computer fails to recognise my external hard drive
I would suggest the external casing of the harddisk that contains its power supply is busted, so you need to change the casing or remive the harddisk from the casing and connect in inside
Feb 16, 2008 | Western Digital Caviar WD2500BB 250 GB...
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
