Question about Efficient Networks SpeedStream 5100 Modem
Cannont Access Modem
I am unable to access my modem using web management. When I connect the modem to phone line and ethernet to my laptop, I get an IP address of 169.254.65.70. I tried resetting the modem but didnt' work. It is a Speedstream 5100 A modem with 060-E141-A08.
  • 749 Answers
1. click START-settings-Controll Panel- Network Connections
2. right click on your LOCAL AREA CONNECTION and select PROPERTIES from the menu.
3.when properties opens, select TCP/IP by highliting it, then click on the properties .
4.once the new window opens titled "internet protocol (tcp/ip) Properties you will need to check the boxs that say "Obtain an IP adress automatically" and "Obtain DNS server automatically"
5. Click on OK
6.reboot
Hope this helps, post if you need further assistance.
Posted on Oct 06, 2008
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
I am unable to access my company's vpn server.
You may have some needed firewall ports blocked on your router. Turn off the firewall temporally and see if your able to connect. Your company IT folks should be able to tell you what ports they need open.
Oct 20, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Hi Currently i am using internet Type: Broadband provided by Local Cable operator Modem:Motorola SB5101i Connection type: PPPoE [with username/password] Using with: Dell inspiron15 Laptop Location:...
There is a configuration facility included with the modem that you should be able to access to help troubleshoot the connection.
The Cable Modem has three active interfaces, the HFC, the Ethernet and the USB and each
interface has both a MAC and an IP address associated with it. When operating normally it is the
IP address of the HFC interface that is used for diagnostic access to the modem. However the IP
address associated with the Ethernet interface is always available to the client side network,
unless it has been disabled by management command. This means that a PC on the client side
can access the WEB pages within the modem using the reserved address 192.168.100.1. This is
a non-routed address so it cannot be reached from the Internet (routed) side of the network
The SB5100 family of modems contain an internal DHCP server, which is active until the modem
registers with the CMTS. In the case of a problem that prevents the modem from completing its
registration, the modem can still give an IP address to the client PC to enable diagnostics access.
This address is given with a very short lease (around 10 seconds) so that as soon as the
registration does complete the client PC obtains its proper IP address from the core network
DHCP server.
Mar 15, 2017 | Arris SURFboard® SB5101 Cable Modem
Unable to connect EpsonTX710W Printer viaNetGear DG384
On your Laptop go to Control Panel-> Printers-> and then add printer. Select the option of network printer and search for your printer. If found add it.
Or Else check the ip of printer from ports tab in printer properties on desktop computer ans search your printer with ip address on Laptop.
Jun 01, 2010 | NetGear DG834G Router
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Modem connects to Internet, but PC can't
Are you using a firewall? Did you tell the firewall that the browser has permission to access the internet (go beyond the local network of the modem)?
Jul 29, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
SBG 900 SECURITY
you probably need to access the web management function for this modem. Using a PC connected to the modem, open a web browser and type into the address bar the address of the router/modem/gateway. This is usually 192.168.0.1 or 10.0.0.1 or 10.1.1.1. If you cannot find this information, find the status of your ethernet connection on your computer (where it tells you you computer's IP and time connected etc). Here you will find a number labeled "Gateway" this is the number you want to type into your web browser.  Once you get this correct you will be prompted for a username and password (by default it will be admin, admin) then you should have access to the configuration of the modem.
Write back if you're unsure of any steps
Jan 08, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Efficient Networks SpeedStream 5100 Modem Logo
328 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
