I have the makita 18v cordless drill and can not get the bit out. It was hand tightened but seems locked.
    Scholar:
  • 125 Answers
Just hold the Black part of the makita, I understand that its an 18v drill, and it has way more torque than a 12V but just hold on to it as hard as you can while you give it some power. You should be able to get your bit out. Once it gets loosened up a little its easy after that. good luck and let me know how that turns out. The Black part should be wanting to spin towards the left. Just hold that in place. Adjust your drill to the lowest speed. Good luck and let me know if this helps
Posted on Oct 05, 2008
Ryobi 18v Lithium cordless impact drill chuck comes loose while drilling
Tighten the screw inside were the drill bits or attachments go this is a reverse threaded screw try using lock tight also
Aug 31, 2013 | Ryobi 18v Variable Speed Impact Driver...
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a 18 volt makita cordless impact driver i can not get the driver bit out it seems to be stuck in the chuck very tight
Try holding the bit with pliers and running in reverse, maybe with a shot of oil. That might free it up. You can also try tapping it (firmly) on the side of the bit
Aug 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I can't get the drill bit out of My Makita 6333D cordless hand drill. I usually have no problem. I did tighten the chuck pretty tight, but now can't loosen it. Help.
put the drill in a vise and using a pair of channel lock pliers grip the chuck and it should come loose will a little tug on the pliers
Sep 12, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do i re-assemble a makita 18v cordless drill
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Dec 21, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
