Dsl faullts cannot get internet computer flashes up no dsl connection but when I use the telephone the internet works, seems to be I need the telephone line open to receive broad band
  • 6,487 Answers
You need to check your DSl line to your Internet Provider so they can properly setup the right configuration for your DSL connection so this problem wont happen again...
Hope that helps..DOn't forget to rate the solution FIXYA thank you...
Posted on Oct 05, 2008
Zoom X7n Dsl 2/2 Modem/router/gw dsl light blinks constantly when trying to connect to Earthlink
Try removing the splitter, if it works then you might have a faulty splitter and you need to get it replaced. You might check if you are using the first phone jack in your house / apartment. I remember that was key when i was on DSL. Hope you get it sorted out, not having a working connection is very annoying.
Nov 18, 2013 | Zoom X7n Dsl 2/2 Modem/router/gw
Zoom X7n Dsl 2/2 Modem/router/gw DSL light will not stop blinking - trying to connect with Earthlink
Earthlink is not your local telephone company? You would need to contact your local service provider. If earthlink set up your DSL thru your local telephone company, you may have to have them contact them. Does your local phone to you or do you subscribe thru what they call a CLEC?
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
I have a flashing icon on my WRT120N linksys router and when i connect my dsl modem to it, i have no internet connection. How do i fix this?
  1. check the line has internet service enable (telephone provider),
  2. check the microfilters on each telephone plugs
  3. check the dsl light stays always on. if not is a line/provider service problem.
  4. enter the router webpage.
  5. configure the user and password internet acess codes. (check the internet provider for your internet account)
  6. check the internet light turns on
Nov 06, 2010 | Linksys WRT120N Router
Setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
Apr 15, 2010 | Computers & Internet
Wht can the problem be when i can see my SSID,
If u cannot connect to the internet, 1st make sure the power LED is not flashing, if it is flashing then power off all your connection device: DSL modem, Router and computer. After that, power on each device in following order: DSL modem->Router->Computer.
Another that u can check is the cable connection. Since your computer can connect to router, then the rest to check is the DSL modem must be connected to the internet port on the router and coaxial port to the telephone line.
YBC (/\)
Oct 04, 2009 | Linksys Wireless-G WRT54G Router
Yes i want to find out if a cable modem will work with your dsl phone internet service?
No.
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Jan 27, 2009 | AT&T High Speed DSL Modem
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Adsl modem not working
First you must have a steady led light on the on Power, Act and Lan, the Sync led will flash until the modem connects to the DSL line. If you are not running a router but only a modem, you will need to create a PPPOE network connection on the computer. If you are using a router with the DSL modem you will need to create the PPPOE connection only on the router. I had recently a problem with the DSL service to my home. My modem showed DSL connected but could not connect the PPPOE connection, the telephone company had to reset the circuit that I am on which fixed the problem. BPCS
Dec 06, 2007 | Acer Altos G500 Server
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
