Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony 32xbr400 manual
I need the service manual for the Sony 32xbr400 TV. Or at least can someone tell me which IC is the vertical IC to check for poor solder joints.
Thanks
I have a Sony 36"
My friend there is a problem in horizontal block there is open resistor near the plyback...
May 14, 2011 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Set will not turn on and red light blinks four times
4 blinks means that you have a problem on vertical section. It may be caused by defective vertical ic or open fusible resistors. Also check for loose or poor solder connections at vertical section. Check if there is a +&-- supply for vertical VCC..
Nov 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power button doesn't do anything, remote doesn't work, 4 blinking lights. Sony kv 36fs120.
you have power issue. short the prongs for a minute. then remove the short wire. then test. if not succesful go to your nearest service center.
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony-27S46 TV standby light flashes 4 times
Can you please confirm the model number? The category is for KV-27S42 and you state in the title you have KV-27S46. Also, when getting the 4 blink code, do you see a horizontal line on the screen or nothing at all? The 4 blinks means no vertical sweep. This can be a bad vertical IC (what you changed already) or no power to the IC or even a bad capacitor in the same circuit. If you know how, check the supply voltage to the IC. If not present, we need to trace the supply line for that IC. I will need to consult the service manual to provide additional details. Please confirm the model so I get the correct part numbers etc.
Thanks,
Dan
Jan 14, 2009 | Sony KV-27S42 27" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Mar 26, 2006 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
297 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
