My old linksys router has stared to allow only one computer to connect to the internet. This is true whether the computers are hardwired to the router or wireless; only the first computer is connected. What got changed in the router to cause this? How do I fix it?
  • 781 Answers
Try the following
1. check the linksys website for a possible update of the firmware..(get the specs on your router before updating the firmware.. if done wrong you may end up with a useless router)
2. also try to reset your linksys router to factory defaults..
Posted on Oct 05, 2008
  • 1 more comment
  • Francisco Cortes
    Francisco Cortes Oct 08, 2008
    where you able to do 1 and 2? if not...please make a comment and we'll try to walk you through the process if you don't how to do it.
    assuming you did completed 1 and/or 2 check the following: you may have a switch instead of a router and possibly your isp has made some adjustments causing the behavior you described:
    http://forums.linksys.com/linksys/board/...
    if it's not an isp problem you router may have been damaged and is oly working as a switch.
    confirm if routing is sitll working (at least locally) by doing the following:
    check if you're getting valid ip addresses (you need a valid ip address to connect to internet and the router should dinamically assigned ip addresses to both of your machines) on both computers: go to start>run> type cmd then press enter, a command prompt console will open, (like good all DOS), type 'ipconfig /all' (without the ' ''s) and press enter you should get something like
    IP Address. . . . . . . . . . . . : 192.168.0.100
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.0.1
    DHCP Server . . . . . . . . . . . : 192.168.0.1
    DNS Servers . . . . . . . . . . . : 192.168.0.1
    check if both computers get something similar but the ip address should vary on the last digit for each computer. if this checks out with what you see test if you can go outside your network by pinging a remote location:
    at the comand prompt type 'ping www.google.com'
    and you should c something like this on both computers:
    Reply from 72.14.205.103: bytes=32 time=13ms TTL=249
    note: if one computer gets an ip address that looks like 169.254.x.x your linksys address is not dinamically assigning ip address and may in fact been damaged (unlikely)
    post your findings.. provide as many details as you can so myself or someone else may be able to provide you with a solution by reading your feedback.
  • Francisco Cortes
    you may also want to ensure DHCP is turned on on your router (if you do have a router and not a switch)... find out what is the address for the configuration page and look around for DHCP and make sure is turned on... save your changes, restart the router and your modem and retest your connection...
    source:
    http://www.daniweb.com/forums/thread3035...
  • Francisco Cortes
    lastly make sure the DCHP client is working on both computers aswell. check the service is started and automatic in the services applet under computer management
Can a dynex DX-ESW5 act as a print server?
No. You need a router to set / obtain an IP or connect it directly to the computer RS232 serial port. No network required, but is old school and may be difficult. Specially with MAC. You are better off getting a new router.
Jan 29, 2013 | Dynex Dx-esw5 10/100 Fast Ethernet Switch...
My Linksys router was working fine with my Compaq Presario until I upgraded to HP pavilion slimline with Windows 7. The slimline has only one Ethernet connection; the Motorola modem also one; and the...
Connect your Linksys router to your Motorola modem through the internet connection on your router. The ethernet ports on your router is for your PC's. The 4 ethernet ports on your router means you can connect up to 4 PC's hardwired to the router. You may also wants to contact Linksys Technical Support Team to assist you on the configurations of your Linksys router.
Aug 31, 2011 | Computers & Internet
It is 2 yrs old and cannot connect to the internet , it was working yesterday and i rearrange tne wires by unpluging them, and when I plug them back in, the internet would not work.I troubleshoot it and...
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 21, 2010 | Linksys Wireless-G Broadband Router
I was trying to connect a new laptop to our home wireless network via wrt54g. on installing our old linksys disc into the new laptop it kept sayin not connected to the internet even though it was hardwired...
Your mistake was to run the CD on the laptop. When a router is working and computers are using it NO CDS ARE EVER NEEDED. Your laptop will connect to it just using what is already in the computer.
When you go to starbucks and use the internet they don't give you a CD to install do they - they just give you a password - that is all you need. The fact that you are hard-wired means you don't even need a password.
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Communication
How many computers do you have? Make sure you can go online first via hardwired. If the internet works fine hardwired, one thing that you can try is change the current channel of the router.
Open the setup page of the router.
1. Launch Internet Explorer, type http://192.168.1.1
2. A username and password box will show up. No username and password is admin
3. Go to WIRELESS tab. Change the channel to 11 and click on Save Settings. Restart your computer and try to connect again.
Jul 01, 2008 | Linksys Wireless-G Broadband Router
No Internet Connection
Hmm... this sounds more of 2 things. Firewall and security. Is this a new unit that you have? If not, i suggest you take a look at the settings of the WAP to ensure you do not have mac authentification on (if it's WEP, you will be asked for the encrypted key, and since you did not mention any of this, i assume it's more of a MAC filter setting, preventing you from connecting to the network).
Alternatively, you might wanna find out if you have the WAP's firewall turned on, preventing you from accessing the network (norton's 360 firewall is a pain in the a**). Also, as a precuationary measure, you might wanna update the latest image of linksys's WAP, to ensure optimal performace. Hope this helped. Thanks.
Jun 02, 2008 | Linksys Wireless-G WKUSB54GS Kit
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
