Question about MTX Thunder TA7801 Car Audio Amplifier
Amp is a mtx 801d not sure
I have two 12in. kicker cvx can i installed them to a mono block amp with out daul vioce coil burning out. some one told me if i install them that way my subwoofers would burn out.
    Problem Solver:
  • 12 Answers
No you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
Posted on Oct 23, 2008
So I just bought a kicker cx 300.1 mono block amp to run my 10 inch comp d 4 ohm 300 watt sub. I ran it parallel and it smells like the coils are burning. Help
That's only normal for the burn in period. Make sure you're not running it in 2 ohm by wiring the sub wrong. That amp is not really 2 ohm stable for a sustained period
Feb 03, 2015 | Kicker Car Audio & Video
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
Mar 30, 2009 | MTX Thunder 81000D Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
HELLO CAN SOME BODY TELL ME HOW TO HOOK UP MY SYSTEM RIGHT I HAVE 2 AUDIOFONICS ADF-272 1200 WATTS AND A MTX 4501 CLASS D MONO BLOCK AND A MTX 801D KIND OF OLD SCHOOL IS LIKE 4 YEARS OLD AND HOW TO series...
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
HERE IS HOW YOU HOOK UP 1 SPEAKER TO 1 CHANNELM DO THE SAM E TO THE OTHER CHANNEL. MAKE SURE AMP IS IN MONO MODE,YOU DONT WANT TO PLAY UR SUBS IN STEREO.AS FAR AS THE BOX DEPENDS ON VEHICLE AND HOW MUCN SPACE YOU HAVE .TELL WAT MODEL CAR AND ILL ET BACK TO YOU. I NEED A FIXYA RATING PLEASE
Feb 10, 2008 | Audiofonics ADF-272 Car Speaker
Audiofonics
i would go with the 801.And ithink u meant the 4501 not 4051.Both super power amps. competition stuff.your woofers are 4ohms dual voice coils.so you can series the coil on eaach woffer and use the two channels on the amp.they play at 2ohms.I think if you drop it down to 1 ohm you really be taxing you alternator that is series power.Yioou would need a special alternator.Even with them running in 2 ohms you better hav eat least a 2 farad cap.OR two batteries.. ! more thing don 't pump it up with window s closeed .you'll pop them.serious dbl. you be pumping.I'm jealous.Rating please and enjoy.
Feb 09, 2008 | Audiofonics ADF-272 Car Speaker
Help putting code in
hello i have 2 audiofinics adf-272 i dont know what kind of amp to hook up with it which one do u think is best for them a mtx 4051 500 watt class d mono block or a mtx 801d 800 watts
Jan 27, 2008 | Car Audio & Video
MTX Thunder TA7801 Car Audio Amplifier Logo
107 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
