Question about Refrigerators
Frigidaire refridgerator #frt21prhw1, not cooling or freezing
Refer and freezer not cooling
  • Anonymous Mar 16, 2009
    refredgerator not freezing or cooling
  • 750 Answers
You said, your frigidaire refrigerator are not cooling
Check the outlet that it is still has power. You can plug a small lamp in to test it.
If there is power, wait 5 minutes before plugging the fridge back in and then see if it reset the system.
And how old is the fridge?
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Posted on Oct 05, 2008
Frigidaire 18.2 cuft top freezer refridgerator either melts or freezes everything
The defroster heating elements are burnt out and won't defrost and causes system to freeze up. Then it won't cool. Unplug ice will melt off cooling fins then it will cool till it freezes up again. Install new defrost heating element. Replace both.
Jan 15, 2014 | EuroCave Performance 283 Wine Cellar
Ice building up on back walls of freezer refridgerator seems then not cold enough or bottom drawer freezing produce
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Frigidaire Refrigerators
Refridgerator won't cool, freezer is OK
if it is a bottom freezer and top refrigerator it is low gas in the system need to be topped up
May 12, 2009 | Samsung Refrigerators
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Frigidaire Upright not cooling
Not enough information but  if you are refering to the compressor as the black housing below, it seems that the compressor is either seized or burnt out.
Oct 25, 2007 | Frigidaire 11.6 cu. ft. / 328 liter...
Refrigerators Logo
637 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
