Make sure the fuel pump is kicking on it won't hurt to check the relay but I have never seen one bad yet it could be the plug on the plug on the end of the wires that plugs on the pump this run hot and it burns the ends alot several fuel pumps are replaced because of this make sure you have power at the pump if you can't hear it run it will only stay powered for a few seconds and then kick off. so you might need someone to turn it on while someone checks the power.
SOURCE: Car started bogging and dying
COIL PACTS GOING BAD OR LOCKOUT ON TRANSMISSION DISCONNECT IT AND SEE IF IT HELPS
SOURCE: fuel pump
replace the fuel pump relay. if no help you will most likley need a new fuel pump.
SOURCE: i have a 1992 suburban 350 motor. truck had no
first thing i would do i would check fuel pressure if you have good fuel pressure then the next thing i would unbolt the exhaust from the exhaust manafold and then try to start engine if the engine starts up and runs fine then you have clogged up exhaust converters
terry - Master tech
SOURCE: where do I spray the starter fluid (air intake?)
Follow the large (4") black rubber hose that runs from the air filter box to the engine. You can remove it at the engine end (attaches to the throttle body...you do not have a carburetor) I'd spray carb cleaner in there...it burns as well as gasoline and won't damage anything...starting fluid is very volatile and can. Normally, after running out of fuel, all that you'd need to do is leave the key in the run position for about a minute and you should get fuel up into the system. If it fails to start after several tries, likely something else has gone wrong and you will need some diagnosis to find our exactly what.
