Question about Acer Computers & Internet
22" ACER MONITOR QUIT
MY MONITOR QUIT AND WONT COME BACK ON IT TRYS THE LIGHT LITES UP AND THEN GOES OUT. ITS NOT THAT OLD JUST GOT IT LESS THEN A YEAR AGO..CAN YOU TELL ME IF THERE IS A RESET BUTTON OR SOMETHING I CAN DO TO GE IT FIXED...
    Champion:
  • 293 Answers
93vette,
Well...what you need it a new backlight inverter. Your old one it's busted. If you got less than a year... you've got 3 yrs warranty on parts. Contact Acer asked them to send you a new inverter... Have a nice day!
Posted on Oct 06, 2008
My acer x223w monitor goes black and the blue light stays on what could it be??
The backlight controller has failed. It can be repaired or replaced.
Feb 20, 2011 | Acer 22" X223w LCD Monitor
When I boot up my computer, it takes my Acer monitor 20 minutes to show the desktop. It flashes the Acer logo, then goes black, then flashes again, and repeats till it finally comes on. Could it be a...
It's probally the inverter board that drives the backlight in your monitor is failing causing the digital board to reset. I think Acer has a 3 yr warranty. If the monitor is less than 3 years, I would call them and ask them to repair it. They will fix it for free if it less than 3 yrs old, it will only cost to you is shipping it to TX. Hope this helps.
Aug 06, 2010 | Acer AL2416WBSD 24" Monitor
The lights come on but nobodys home, i get a dark gray screen, it trys to to start then stops the lights stay on
Try plugging your laptop into a desktop monitor to determine if it's a display problem or goes deeper than that.
Dec 24, 2009 | Acer Aspire 4720 Notebook
The acer aspireone screen wont light up when i turn the computer on. the power light comes on, but nothing else happens.
The screen looks to be bad.
Usually the internal lamp burnt out.
If you need to use it, change monitor and try it.
This way you make sure that the video card is working properly.
Don't forget to rate this answer if it helps
Dec 24, 2009 | Acer 22" X223w LCD Monitor
I HAVE A SAMSUNG 2253 22' LCD MONITOR,POWER LIGHT FLASHES,AND SCREEN STAYS BLACK ,IT TRYS TO LIGHT UP ,BUT STAYS BLACK,MY OLD TINY 15' LCD WORKS FINE ON THE SAME COMPUTER,MY 22 USED TO WORK FINE??????
A flashing power light like that indicated a blown power supply. Your monitor should be under warranty with Samsung. Check the mfg date on the back sticker, if it is less than 3 years then contact Samsung. If it is out of warranty then contact us at tech@ccl-la.com and we can get you the info you need to do the repair yourself.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Computers & Internet
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
The sceen turns a yellowy tone and then goes back to normal
Possibly there's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring it to an authorized service center to fix the problem. regards
May 29, 2009 | Acer P223W 22 inch Monitor
Monitor goes to black and back on
MY LCD 22 ACER MONITOR GOES O BLACK AND I CAN'T SEE THE MENU
Nov 21, 2008 | Acer 22" X223w LCD Monitor
Acer 2032 w will not stay powered on
If you can splice wires, this will fix it. First beat the old Acer power supply to death. (God, that felt good) Then cut the wire off the old brick and splice it onto a laptop power supply that's rated at 18 or 19 volts @ more than 4 amps. Dell uses them and I used one from an HP dv2000 that cooked itself to death. The Monitor runs on less than 3 amps and is quite happy at 18 or 19 volts. By the way, the white wire is positive and the black wire is negative. Don't worry about those four pins on the plug. If you look on the case of the old brick, you'll see that the pinout is quite simple - 1 and 2 are positive, 3 and 4 are negative.
Feb 18, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Computers & Internet Logo
468 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
