Question about Protron PLTV-32 Television
Proton pltv 32C
What is the resolution of 1366x768 pixels? Is it 720p?
1080i or itll do 720p
Posted on Oct 05, 2008
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Sep 07, 2014 | Televison & Video
Where I can buy a Remote Control for Protron TV 32
Setup code to check with Proton TV is 1288. If you wish to get more detail about which brand remote control have setup codes to Proton TVs, check these sites. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'. Locate the exact model remote control, and buy than one according to availability. Many brands will have setup codes. Check all of them.
Aug 21, 2013 | Protron PLTV-32C LCD TV
How to increase screen resolution from 800x600 to 1366x768
You need to get the correct video drivers for your Graphics card or on-board graphics chip. Just go to the support site of the graphics card or if it's on-board video go to the support site of the motherboard to get the proper drivers. Once the correct drivers are installed, you will be able to increase the resolution.
May 24, 2012 | Intel Desktop Board D815EEA2 Motherboard
We own a proton pltv-32c. the image coming in is larger than our screen (or the ratio is off). Basically the top and bottom of all images are being cut off (same for TV and video watching). What to do?
Check the FORMAT option in the OSD (on screen display) menu. It may need to change.
It's on page 15 of the User's Manual.
Format
Controls the picture format. The options are 4:3 and Full
(16:9-widescreen).
Or you could reset the tv by using the All Reset button on the menu.
All Reset
Resets all options to factory-default settings.
See page 23 of the User's Manual.
You can get a user manual from;
http://imageuploads.googlecode.com/files/PLTV-32C-owners-manual.pdf
If you do not have Adobe Reader to read the manual you can get it from;
http://get.adobe.com/reader/
Mar 27, 2011 | Televison & Video
What pixel is this tv 780 or 1020
http://www.amazon.co.uk/Philips-32-5331-HD-Ready-LCD/dp/B000IUZ944
  • Resolution: 1366 x 768 pixels
  • Display Format: 720p
  • Supported DTV Resolutions: 480p, 720p, 1080i, 576p
If this helps or solves the issue, please rate it and give a testimonial for my response.
Thank You,
Brandon
Dec 22, 2010 | Philips 32PF5331 32 in. HD-Ready LCD...
Proton pltv-26 sound works but no picture
If you have PLTV-32, check to see if your AC adapter is putting out the 24vdc for the backlight inverter, you are getting the 12vdc from the adapter for the sound and for the processor to turn on the TV, otherwise you may have backlight inverter board problems.
http://www.lcdpayless.com/productpage.php?productId=6332
PLTV-32C has power supply module inside the TV: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv-32+power+supply&um=1&ie=UTF-8&ei=PWVvTOy6M5H4swOciO3DCw&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCwQrQQwAw
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Protron PLTV-32 Television
Insignia IS 26 Inch Lcd TV Problem no signal VGA Input
Most likely this is a resolution issue. Set your computer's output resolution to one that is compatible with the TV, usually 1366x768 for a 720p Insignia TV. More info can be found here.
Mar 05, 2010 | LG 26LG30 26 in. LCD TV
PC input
output resolution is different from supported input resolution you need to check in the manual which resolutions are supported. the 1366x768 is the screen output or what it scales the supported resolutions to for the screen output. as eg: 480i low resolution gets scaled (to the best of it's ability) to the output resolution 1366x768. altho the scaling isn't smooth it displays all pixels. the more information the set recieves the better the scaling.
Feb 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
What difference between broadcast supported and broadcast displayed
1080i is yesterday's resolution and now it's up to 1080p as the standard.  Who knows where it may end up.  I suppose there will be 3-D actors prancing around the living room.   Wee.
Good luck.
www.proton-usa.com
Nov 24, 2007 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-32 Television Logo
51 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
