Question about Dell Inspiron B130 Notebook
BOOTING UP PROBLEM FROM THE BIOS
My laptop comes on with dell logo screen then after maybe 6% of the white bar goes across it stop. I did a boot diagnostic by holding down the FN key and cutting it on and now it show the 3 light. #1 (cap lock light) is off , #2 (num lock light) is is on , #3 (stroll lock light) is blinking. do anyone know what this mean? Dell tech-support don't know.
  • 3 more comments
  • STICK27 Oct 08, 2008
    Experts #1: I try disconnecting and connecting back the cmos(bios)batteries but still have to same problem and the batterie is good i tested it and it has 3.12v. nice try but didn't help.
    Experts #1: I try disconnecting and connecting back the cmos(bios)batteries but still have to same problem and the batterie is good i tested it and it has 3.12v. nice try but didn't help. Also ginko i can't reinstall windows because the bios is not booting all the way. It stop at 6% loading on dell bar.
    I did a dell boot diagnostic test by holding down the FN key and cutting it on and now it show the 3 light. #1 (cap lock light) is off , #2 (num lock light) is is on , #3 (stroll lock light) is blinking. do anyone know what this mean?
    Here is all that i try: disconnecting and connecting back the cmos(bios)batteries but still have to same problem and the batterie is good i tested it and it has 3.12v. nice try but didn't help. I also try disconnecting and reconnecting hard drive, both modem, cd rom drive. try changing memory chip.
    Also ginko i can't reinstall windows because the bios is not booting all the way there for no cdrom drive for reinstalling. It stop at 6% loading on dell logo screen.
    dell boot diagnostic test is trying to tell me something with these light pattern. It show the 3 light. #1 (cap lock light) is off , #2 (num lock light) is is on , #3 (stroll lock light) is blinking. what does this mean?
    thank you
    Come on now how can i reset the bios back to the default setting if i can not get into the bios setting to do so. It freeze after 6% of dell logo bar load. no f-key working no cdrom.
    all i can do is turn off.
    sorry but that web page code is for desktop computer not for laptop. I know about these code.remember this is a dell B130 laptop.
    Sergeant:
    Champion:
  • 334 Answers
HELLO REST IT HOLD F 11 G2 DEL OR TAB KEY ONE OF THEM TAP DURING START UP THEN GO IN AND DEFULT BIOS OK IF U CANT GETTHAT FAR TELLME
Posted on Oct 08, 2008
  • 7 more comments
  • nick helpap
    nick helpap Oct 08, 2008
    NO CD ROM DRIVE GET USB ONE EXTNERAL BOOT FROM THAT OFF THAT WAY PULLIN BATTERY AMND MAIN POWER FROM MOBO WILL DEFULT BIOS
  • nick helpap
    OH SO YOUR ON DESKTOP NOW THEN MOVE JUMPER ON PIN 12 TO 23 FOR 5 SEC THEN BACK ON CMOC JUMPERS ON MOBO
  • nick helpap
    ALSO THEY MAKE FLASH BIS TOOL FOR FLOPPIES DISK STICK IN BOOT UP REDOES ALL YOUR BIOS TO DELL SPECKS BUT SURE U DNT HAVE FLOPPY U WOULD NEED EXNATLAL ONE ALSO AGAIN PULL MAIN POWER FROM BOARD AND BATTERY THEN ON LABTOP BIOS RESETS MABY LOOK FOR CMOS JUMPER ALSO
  • nick helpap
    GET IN BIOS BEFORE SHE TRYS TO THINK IF U CAN HOLD THAT F11 F2 OR F3 OR DEL OR TAB KEY SUMTIMES HOLDING TAB KEY WILL SHOW U WHATS BAD MABY HARD DIRVE NO GOOD ON IT OR LEAK IN RAM OR BAD POWER
  • nick helpap
  • nick helpap
    MAKE SURE PULL MAIN POWER WHEN U DO BATTERY OUT BOTH BATTERIES OUT WHEN U DO RESET WITH POWER OF IT IF THERS NOT A CMOC JUMPER TO CHANGE PINS THEN GOTTA DO IT HARD WAY PULL MAIN POWER AND BATTERYS NOT JUST BATTERY WILL NOT DO IT STILL HAS POWER HOLDING IT IN
  • nick helpap
  • nick helpap
    SO IF IT IS THAT ONBORD SOUND CARD USALLY BIOS SET TO AUTO GO GET USB SOUND CARD OR PCMIA ONE SOUND BLASTER MAKES AT BEST BUY STICK THAT IN see if bypasses it to get u in boot f8 safe mode or then boot to xp cd reformatt it all redo it
  • nick helpap
    also even if u defult it wont help u relly nee dto disable onbord sound and lpt prost irqs once in there
  • 63 Answers
If the number lock light is on, caps lock light is off and the scroll lock key blinking - it means to says that your system is having a AC 97 codec detection error.
what you need to do...
First Reseat the modem - if no go then...
Replace the modem - if no go then...
Replace the system board...
  • Janet Nery
    Janet Nery Oct 08, 2008
    I am a Dell Systems' Expert and this is what I have to say. I have been dealing with Dell products and for this type of issue...this is what i have to say...
  • Janet Nery
    It is the modem card that is causing the problem. try to get it out of you system. go to support.dell.com and enter the service tag of the computer. you will be able to get the manual in there.
  • 4,889 Answers
  • Dell Master
  • 13,433 Answers
Ok, if the bios is corrupt, the bios needs to be flashed, as you can't do it, you will need to send it for dell repair, as far as I know the bios can't be removed easyly from the motherboard, it would need to be soldered out possibly. Best to let dell handle it.
  • Ekse Oct 08, 2008
    or possibly other motherboard problem.
  • Ekse Oct 08, 2008
    I recommend you contact dell again and set up repairs
    http://support.dell.com/
    I don't think this is fixable at home.
    Genius:
  • 1,913 Answers
First tell me are u able to enter in bios setup when u strat the laptop press F!or F@ or DEL
try this key to enter setup of bios.
if u able then your system is ok.
then also check to press F* when u start if u get safe mode and other option go to safe mode then go to run and run "chkdsk /r"
then press "y" then resrt the laptop.
may be your hard disk has bed sectors.this [process remove it.
  • kishor khatri
    kishor khatri Oct 08, 2008
    yes your hard disk got bed sector.
    try to delete the partitton then format al partition try this 2 -3 toimes if failed but u can install new windows definetily.
    delete all partiton then create all.then fromtat the c patrion with NTFS.
    thats all
    best of luck
    u can do it believe me.
  • Dell Master
  • 6,487 Answers
Try resetting your BIOS to its deaafault settings that will fix the problem....
  • Dell Master
  • 19,396 Answers
You need to reinstall windows, either using recovery disk, windows install disk, or if present, the built in system recovery tool.
Posted on Oct 06, 2008
    Scholar:
  • 116 Answers
Off the pc .remove the cmos battery and then insert the cmos battery and then again restart the pc and check.
2 Suggested Answers
ariyako
  • 18 Answers
SOURCE: BOOTING PROBLEM DIAG PROBLEM
What os you running? it booting problem or diag problem? If you can access windows desktop, you can try use Microsoft Bootvis to Diag your boot problem and Bootvis also can optimze you boot time :)
Posted on Sep 26, 2008
I have a dell laptop. When I turn it on Windows comes up and it stays on the screen that says windows and has the bar that goes from left to right to tell you it's booting. It never stops doing that. I...
Shut the system down by holding the power button for 5 seconds or more. Turn the system back on, as soon as the blue dell logo goes away tap f8 on the keyboard. This should bring you to a menu from which you can select "safe mode". See if it starts in safe mode. If so, troubleshoot further from there. If not press f12 on the dell logo and choose diagnostics. Run a quick scan, see if any errors are returned for the hard drive.
Feb 24, 2011 | Dell Latitude D600 Notebook
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Dec 13, 2009 | Dell Inspiron XPS M140 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
When i start up my dell inspirion 6000 laptop the logo comes up and then screen goes black
When you see the Dell logo, it means the system is booting and you see the splash screen that is generated on the motherboard.
Apparently this is where it is stopping.
Here's what I would do: First when you boot the computer, press F12 to get the boot options. Choose the diagnostics and run the system diagnostics.
You can also try to press F8 to get the computer into safe mode, but I'm thinking if you see nothing other than the splash screen, that may not work. If you are presented with Windows boot options, choose safe mode and do a system restore.
The last thing you can do if you have the Dell system recovery disk is try to do a repair from that CD if it allows you to do so.
Nov 06, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 won't boot
The initial Dell Screen you see at the begining is your BIOS access. Push F12 repeatedly when you see this screen and it will take you into a system restore mode. It will let you boot from CD first (which your PC is not set up for). You should be able to start the CD fine from there.
Sep 21, 2009 | Dell InspironTM 1501 Notebook
Black screen on Acer 4720Z
If your booting to the splash screen ( ACER Logo screen ) then it goes black reboot - access the bios and do a bios hdd test - you mostlily find your hdd has died. Head scrash
Mar 07, 2009 | Acer Aspire 3690-2196 Notebook
Sep 26, 2008 | Dell Inspiron B130 Notebook
Dell OptiPlex GX150 won't do anything.
try going to the bios by pressing f2 or delete key on the keyboard at the dell logo.
if you are able to enter the system setup screen, reset the bios.
to reset the bios, press num lock, caps lock and scroll lock so that all 3 lights on the keyboard are on.
press alt + e and alt + f keys.
press esc twice
then select save changes and exit.
also try booting through the safe mode by hiiting f8 on the dell logo.
you can also try booting through the dell resource cd or win xp cd.
Aug 06, 2008 | Dell OptiPlex GX150 SFF (GX150BLACK) PC...
Dell Inspiron B130 Notebook Logo
243 people viewed this question
Alun Cox
