Question about Panasonic Televison & Video
My Panasonic projector, Model #PT-L592U, Serial #SL7510277, was working fine for about 35 to 40 hours, when it it started separating the colors some. So now I have these vertical green and blue lines coming from the white, and a few of the other colors are doing the same thing. Is there anything I can do myself? I'm a poor college kid who got the projector for 160 bucks with a blub that only had 216 hours on it. don't really have money to take it to get repaired though.
  • gladeeader Oct 06, 2008
    thanks jomabug, but there is no option for conversion in my menu on this projector. In my other research on my issue I found out that the particular projector I have is notorious for the boards failing in it if the projector is used for too many consecutive hours and it over heats and does exactly what I did. I accidentally left a rockband menu screen running when I went and picked up and hung out with my girl. i left it on for probably close to 7 or 8 hours, needless to say within the next couple of times using it it started to seperate and that was that. So sad because rockband was so much fun on a 14 foot screen, I had just barely built a 6 foot projector stand with lots of shelves for all the receivers, xboxes and everything. its all useless without a projector now. The new boards to fix it are like $1400 which is way out of my budget. and doing all the work on it myself would be way over my head. I really appreciate you trying to help though jomabug.
    Genius:
  • 1,148 Answers
Know not all projection tvs have this,, but my rca hdtv projection ,,does ,, check in your menu for conversion,, it should have it ,,anyway it realines the colors,, youve got to do it every couple of weeks,, or if youll move a projection tv,,thanks,,
Posted on Oct 05, 2008
How to rest alamp hour on panasonic tv with a universl remote model pt 432-c14
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Panasonic ET-LAM1 Projector Lamp for...
I think I may need a green projector ??????
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Jan 10, 2008 | Panasonic PT-56HX41 56" Rear Projection...
Why does the lamp shut off on the Panasonic PT-AE1000E Projector within 1 minute of starting?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
May 26, 2014 | Panasonic PT-AE1000E Projector Lamp...
Problem panasonic pt 61lc27
have a nice day!
Apr 14, 2014 | Panasonic Office Equipment & Supplies
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
Total Expected life (in hours) of a Panasonic DLP Projector
The projector lifetime has a lot to do with maintenance and environment. Over time, the LCD panels will start to deteriorate. I worked for a rental company where these units were in constant use. After 5 years, they were still going strong. Realize though, that these were highly maintained: constant cleaning via compressed nitrogen to remove dust, lens cleaning and filter changing on a regular basis. Checking for proper fan function and complete disassembly and checking for connections etc.
A word of caution: DO NOT work with the LCD block unless you have access to a clean area and have training. The tolerances here are very small. Slight changes can severely alter the picture quality and all adjustments should be left to a professional.
Hope this helps,
Dan
May 11, 2010 | Panasonic PT-D5600U DLP Projector
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Televison & Video Logo
135 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
