Question about Lexmark Office Equipment & Supplies
My COMPUTER WON'T READ CD TO SET UP PRINTER. COMPUTER WAS REMAPED
    Master:
  • 505 Answers
Go to my computer and see if the CD is listed there or not. In case the CD drive is not listed check in the device manager. Go to registry editor by yping regedit from start-run.
Follow the directions here to delete the upper and lower filter values in the registry. Then remove the device from the Device Manager and reboot:
http://support.microsoft.com/default.aspx?scid=314060
http://support.microsoft.com/kb/320553/
Posted on Oct 05, 2008
Cd recorder won't read blank cd
If it is a older CD Recorder, You have to use disc,s that stay music on the label. Disc,s for burning music from a computer will not work in them,
Dec 04, 2012 | Tascam CC-222mkIII CD Player / Recorder
My computer won't open the installation CD so I can install the printer....help please! Thanks you
if the CD for your printer does not run automatically there is another way to install it
1. click start menu
2. click computer or my computer
3. look for the DVD/CD drive and right-click on it
4. click explore
5. then look for setup.exe and double click it.
Sep 09, 2011 | Office Equipment & Supplies
Will not play cd
It may be that itis not set up to read burnt CD's. I have a Rotel DVD but it won't play burntCD's. This is due to the fact that burnt CD's are missing some headerinformation that regular CD's have. Here are some further steps to check
Jul 18, 2011 | Technics Audio Players & Recorders
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
Problem is in top rev range is braking down and backfiring this is a 2010 rmz 450
You need to most likely have the TPS checked (set at full throttle not running 4.85 volts) and or CDI remaped at dealer
Aug 17, 2010 | Suzuki RM-Z 450 Motorcycles
INSTALLATION ON PRINTER DRIVER
Close the manual. Open Windows Explorer and navigate to the CD. Explore the CD looking for a driver folder or a setup.exe command and double click the command which hopefully will set up the printer driver. If there is a driver folder, check to see what kind of files are there. If they are *.dll or *.sys files then you have to use Windows control panel to install them. Let me know what you find.
May 29, 2009 | Canon FAXPHONE L80 All-In-One Laser...
Set up fax for MX3l0 canon
are you trying to instal the cd? if so i would try putting it inthe dvd writer combo as that can also read cds...it should autostart....usually itll tell you not to plug in the printer to the computer til the drivers are installed....try that an let me know :)
Sep 30, 2008 | Canon PIXMA MX310 All-In-One Printer
CAN NOT INSTALL THE PRINTER. ONE
Hi it could be that you have used the wrong cd as some printers come with a windows & a mac cd,
i suggest you go into the printer folder and delete the printer if infact there is one,reboot then try again with the correct cd,read the lable on each cd so you can used the correct one.
good luck
Terry
Mar 11, 2008 | Computers & Internet
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
