Question about Panasonic Microwave Ovens
Unit will not get hot, timer turns off at #23 1.23,5.23, 3.23. When the time get at 23 the unit will stop (dam girl friend) Jackson
  • Panasonic Master
  • 9,047 Answers
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Oct 07, 2008
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
http://waterheatertimer.org/ST01C-program.html#ST01C
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
Jun 21, 2011 | Microwave Ovens
Will only run for 23 sec, then shuts down. hit reset and it will run for 23 sec again. THis happened after it was exposed to a boiling pot of water. The run time is very consistant before stopping,...
mcdevito75 here, Sounds like the timer mechanism which is most likely transistor board is wet or shorted, see any appliance repair shop in your area for help.Or Check the owners manual for repairs.
Jun 28, 2010 | Panasonic NN-S254BF Microwave Oven
My Kenmore 721-63259301 manufactured Sept. 2007 recent stopped working. I first noticed the issue as I went to reheat some leftovers. The unit powered on (internal light lit up turntable rotated timer...
Sorry I can't help you but we purchased this same model 11 months ago and ours just stopped heating this week. Sure expected it to last longer than this.
Jun 12, 2010 | Microwave Ovens
Whirlpool Roper Microwave MHE14XMB turntable stops turning
Hello :
The turntable has a separate motor under the unit(inside) that is quite small..... They just do go out from time to time..!!!!! Just remember to set the timer for shorter periods of time on items that require long cook times and turn it around the other way . Repairing is a bit expensive . You can ask first .
good luck .
please rate .
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
Panasonic NN-S533WF Microwave
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Sep 29, 2007 | Microwave Ovens
MW stops after 23 seconds.
PLESE CHECK RELAYS ON PCBOARD .ALSO TRY DISCONNECTING ALL CONNECTIONS TO FRONT PANEL LEAVE IT DISCONNECTED 5MIN THEN RECONNECT AND TRY THE ELECTRONICS SHOULD RESET .HOPE I HELPED BIT OF A WEIRD FAULT
May 09, 2007 | Panasonic NN-S553 1350 Watts Microwave...
No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Apr 26, 2007 | Sharp R-1492 Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
