Activesync 4.5 no longer recognizes my Treo 700wx. I uninstalled the program, removed the registry files and reloaded active sync on my PC. It worked again for one day. Now I have tried that again twice and I can not get active sync to work. I also removed Windows PC and Windows PC 2 from my phone.
Currently activesync tries to sync but states that there is no partnership.
-   I re-installed active sync, but it still doesn't establish a connection with my phone.
-   JayS1951
Nov 04, 2008
-   I have a Verizon PDA and the same problem - worked October 27th and since then it has not worked. Removed activesync and then reinstalled, but to no avail...HELP!
-   Guest
I had the same problem. This problem is prevalent on Verizon phones as I have figured out online. I had the same issue as well.
Here is how I fixed the problem:
Go into Start -> Run (type regedit.exe) [Hit Enter or click on OK] -> HKEY_LOCAL_MACHINE -> SOFTWARE -> Windows CE Services.
When you get to Windows CE Services, click on it and the look into the viewing panel. Look for GuestOnly. Double click on it. A prompt will come up to Edit the DWORD Value. Change the Value data from 1 to 0 and then press Enter or click on OK.
When you connect your device, it should be fixed. You computer will prompt you to set up a partnership between your phone and the computer.
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? ...
(More)
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? I am worried if the phone quits I lose the use of my PDA and all my info. Help
Whem my server (AlJawal) ask me to sms to download seting they anwer that they do not reconice the...
(More)
Whem my server (AlJawal) ask me to sms to download seting they anwer that they do not reconice the phone
Bad screen .....Unit has very little time on it...Maybe 5 hours Has been sitting for years in home...
(More)
Bad screen .....Unit has very little time on it...Maybe 5 hours Has been sitting for years in home Went to use it and the screen is segmented...unreadable Can I replace the screen Thanks, Pete
