E01 Error on pioneer plasma Hey, I also had the same problem. had being the key Phrase! Here is what I did. First of all the receiver box that comes with your plasma TV is most likely the culprit. All this box does is convert a analogue signal to a digital signal ... That's it... well it also gives you the option of using multiple input connections. See pioneer does not even make this box anymore. so pretty much forget the box. you know the system cables that comes out of the box and plug into the bottom of the plasma. one of those cables are nothing more than a DVI-D cable. I have comcast as my cable provider. There DVR cable box that my cable company provides sends out a digital signal. (HDMI out) so this is what you do. go to your electronics store. and ask for a DVI-D female to a HDMI male converter. They are 19.99 maybe a few dollars either way. connect that to the DVI-D end of your system cable and plug it into the HDMI out on your cable box. and There you go ! See basically you have a 50 inch Plasma computer monitor. the old box was designed to convert a analogue signal to a digital signal which is the signal that your plasma needs to display an image. before to long everything is going to digital anyway....... I hope this works for you.. It worked for me! Ive read all the other threads and none of them worked. let me know what happens!!!! I wish someone told me about this!!!!! it took me a few months to figure it out!!!!!! Peace.
  • 1 more comment
  • skamz1 Nov 12, 2008
    same here
  • Baskey1000 Jan 09, 2009
    I have the same problem and thought I'd try a Scart to HSDI converter. The one I bought didn't work and the screen kept switching off as before.
    However, has anybody has tried variety with success?
    http://www.automatedhome.co.uk/New-Produ...
  • dj_coy Jan 13, 2009
    Peace.
I've got an E01 error on my Plasma TV . It's a Pioneer. There 's anyone who can help me? Tks ALX
Posted on Oct 15, 2009
Mine did the same thing (E01 ERROR). While this adaptor helped, it is not a clean fix. Going from cable box HDMI out to the TV's DVI-D female connector will give you a picture, but 1/4 of the screen is blank/black. You cannot "stretch" screen on the cable remote either. Pioneer says to mail the media box to Long Beach, CA. There is a $500.00 (!!!) flat fee to repair the box!! Mine is on the way right now... Basically, the TV will not work correctly without the "brain" being perfect. This set cost me over 7 grand in 2003 so this is a bit hard to swallow.
Posted on Aug 16, 2010
  • HEATHER MINER May 23, 2013
    i also have a E06 CODE POPING UP TO
I've since found a solution to the E01 error as suggested by Alex.   Have a look at the bottom of this thread http://pioneerhdblog.com/?p=87.  Basically there is a relay near to the on/off switch which if you take off the top and force the connectors together (I put a piece of a match in mine to force the connections together) and as long as you're sensible and switch off media box when not using it, to ensure it doesn't overhead, you should be ok.
Stuart
Posted on Jan 12, 2009
  • legends72 Jan 09, 2013
    I was wondering if this code will come up if the reciever isnt plugged in.
We fixed our 50 in. plasma screens e01 error.
I work in a electronic service shop, I had a tech take a look at the control box. we found several cold (poor) solder connections on the power supply and power switch. The tech resoldered the connections. The unit has now ran for 5 days and no problem since. before it may run 5 min. to 8 hours before dropping out. If you no somebody who does componet level repair they can most likely fix it.
Posted on Aug 20, 2009
I am working on a pioneer plasma ddp433pu, After replacing the power supply i got an error code of E01.What do I need to do to get rid of this.. Will it go away if I hook athe audio video box with the...
No, what this code is telling you is that you need the box that runs the set .... The tuner or control box for the set. I may have one that is left over from when i used to have a business if you need one. Let me know if i can help u further.... Good luck and have a great day...HDTV GURU JAY
Apr 06, 2011 | Televison & Video
I have an E01 error message what is it and how do I fix it
I have an E01 error message what is it and how do"tv pioneer pdp-503pe"
Nov 20, 2009 | Pioneer PureVision PDP-503HDE 50 in....
Pioneer plasma 42 tv with external media receiver 2003 model yr flat screen goes on but receiver light red (not green) and screen gives E01 code? There is a cable from receiver to flat screen seems to be...
If the media receiver was powered up whilst the cover was off or loose, you will get E01 and nothing else until the media receiver is reset in the service mode. There is an anti tamper switch that is activated when the lid is removed.
To do this you will need the special service remote control and the service manual, may be available online and through a Pioneer service agent.
Apr 23, 2017 | Televison & Video
The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Aug 19, 2009 | Televison & Video
Pioneer Plasma
hello have you got a media box if so id check the it for dry joints in the power supply good luck
shaun
Apr 04, 2009 | Pioneer Televison & Video
Light flashes green than a code E06 and E01 comes on than tv off
E01 is relay contacts failure on psu board in media box
Parksy HK
Now someone find E06
Nov 22, 2008 | Sharp Aquos PZ-43HV2U 43 in. Plasma...
Plasma e01 error
Hi. Had all the symptoms with my Pioneer 43" plasma with RO3E receiver that have been previously posted. I got so fed up with it turning itself off that i decided to take the top off the receiver and look for the dry solder joints on the power supply board that some have posted to have cured the problem. I removed the power supply board (which involved removing an interface unit which is mounted above it) and found no issues. I then proceeded to remove the switch board which is placed in front of the power supply board. When i removed the electrical connector which i found not to be fully inserted, i noticed that there was a brown burnt stain in the middle of the connector plug indicating a possible poor connection. I removed the electrical connector from the unit completely (the other end connects to the adjacent board with the fuse on it) and cleaned the connector plug with electrical cleaner and re-inserted it into the receiver and built everything back up. I am happy to report that the tv starts up first time every time and has not turned itself off since. I have included a picture of the offending plug in its built up state (it is the one with the row of black wires with one red wire). Do not attempt to do this unless you are suitably qualified.
Jun 09, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Pioneer Plasma
maybe you can bring it at any pioneer service center and have the IC's reprogramed.you can try that...
Mar 12, 2008 | Televison & Video
Televison & Video Logo
8,196 people viewed this question
Top Televison & Video Experts
Electro Med Services...
