My computer stats up and say error loading operating system
  • 3 more comments
  • runbeezy Oct 05, 2008
    Starts up
    How do i fix this
  • no1_2talk2 Oct 05, 2008
    i have a sony vaio, that when you turn it on it runs thru the bios to the windows page, like its loading windows then shuts down. it will not restart unless it is unplugged and pluged back in. any ideas?
    no that didnt help i didnt have a flopply disk in there. I have a Windows 2000
  • Francisco Cortes
    Francisco Cortes May 11, 2010
    what operating system did you have... windows 9x, 2000, xp, vista?
It has xp home, and there are no disks in the a drive or the cd rom. after reading some more on here, i believe the cooling fan may be bad, but would this cause it to have to be unplugged and replugged to restart?
Posted on Oct 05, 2008
  • 781 Answers
Did you check if you have a floppy disk in the floppy drive?.. if you do take the floppy disk out and restart.. if that did not work.. post back.
  • Francisco Cortes
    Francisco Cortes Oct 05, 2008
    you may have an issue with your cpu.. you're on the right path.. I would suggest to check inside and undust your system with compressed air, particularly any items like fans and heat sinks on top of any components specially your cpu.. and test...
  • Francisco Cortes
    for runbeezy
    your problem is that your computer can't find the active partition or the boot sector and it could be because of a few things:
    1 you removed the active partition: if you messed up with the the active partition you need to get a windows 98 startup disk and with fdisk to set the active partition back again if possible. (don't forget to set your floppy disk as the first boot device in the bios:
    2 your boot sector has been damaged
    3 your hard drive may have failed
    4 your bios and your os are not liking each other
    for 2 and 3 try the following:
    you may want to try repairing the boot sector by rewriting it (you may have some knowledge on computers as that would make things easier for you)
    you need your windows 2000 disk
    1. put your windows cd in the cd drive
    2. restart your system and go into the bios and change the goot order to have the CD DRIVE BE THE FIRST BOOTING DEVICE ( for instructions on how to do this click here:
    3. save your changes before exiting bios
    4. restart your computer.
    5. let the computer start running the windows setup program from your windows 2k cd.
    6. once you get to the windows setup screen click on R for repair windows
    7. select the option that allows your to repair windows with the recovery console: C
    ********** from this point on things could take different paths
    1. you may get a message saying your hard drive can't be read:
    a. if you have a problem with the hard drive..check that is connected and powered up, and if you find a disconnection just adjust, and restart without your windows cd in the drive and see if your system starts
    b. if your hardware is all plugged in you could use the following commands at the command prompt to recover the master boot sector/record:
    type fixmbr and press enter and then once that command is completed (once you get the prompt back) type fixboot and press entered
    if that completes too, type exit to exit the recovery console, take the cd out and try to restart again.
    c. if you try fixmbr and fixboot and you get a message saying the drive can't be found you have a hard driver that simply failed.. at this point you could try to get diagnostic tools from the hard drive manufacturer website:
    for 4 try the following:
    your problem could also be your bios and you may have to flash your bios (update your bios)
    hope this helps..
Error loading operating system
You need to reinstall the Operating System with the help of recovery disks.
Feb 11, 2013 | Acer Aspire 5334 15.6" Hard Drive Caddy...
I am having problem loading operating ysyem
this is the problem if the system files have gone corrupt. you will have to do system recovery on the computer. recovery is the process of reloading the operating system with the recovery discs. by from the number given 678-715-3329. give the information they need of your computer and they will ship you the right set of recovery cd. put the first cd inside and shut the computer off then restart the computer and follow to put the rest cd as the instruction comes on the screen.
May 13, 2010 | Averatec 3200 Notebook
I have a Sony Vaio VGN-N130G. It crashed and I am trying to get it to reboot from the recovery disc but after the first disc starts the Complete C drive thing it stops and says ERROR 400 and can't...
Make sure that the operating System on the recovery CDs is the same as the one on your computer.
If you are trying to recover from a CD with Vista and your computer operating system is Win-XP that will not work.
Other Thing may be you had a hidden partition and some how you over written it or it is damaged.
check the hard disk partition stat.
Nov 27, 2009 | Sony VAIO VGN-N130G/W Notebook
When this error pops up, it normally means you must reload your Operating System off of the disks that came with your computer. Put Disk 1 in the drive and restart the computer. Hold the F12 key down and select the DVD as boot device. Follow prompts to reinstall the Operating system. Good luck !!!
Nov 09, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
I will assume that the that the computer is not booting. The error you describe is a boot sector error. i would recommend to boot the computer from DVD and wipe the hard drive and reinstall the operating system. If you not the techie type take the computer to a technician.
Sep 30, 2009 | Microsoft Windows Vista Ultimate Edition
Error loading operating system on a dimension 4550
Need new hard drive. If that fails then the controller on the motherboard is shot and its time to buy a new computer.
Jun 05, 2009 | Dell Computers & Internet
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
Error : loading operating system
plz try to boot in safe mode run check disk and then boot normally, if the problem arises then try by repairing the operating system. plz post your findings
Jan 12, 2009 | HP Pavilion ze2000 Notebook
Error Loading Operating System
It seems your OS has been currepted, so you should re-install your Operating System.
Mar 24, 2008 | ASUS P4S800-MX Motherboard
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
