Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
1004F Rinnai Gas Heater
I have a 1004F gas heater but NO manual with it. We are trying to learn how to use it. What does economy button mean? When it is not on economy it goes above the desired temperature setting but when it is on economy it never reaches the desired setting. Can you help???
  • clancy13 Oct 06, 2008
    Thank you, thank you, thank you....finally someone helped me to get the manual. I really appreciate you passiong along the link...Clancy13
I found the manual online... I have the same thing, and had a couple of problems with it. I'll try to paste the link here: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf It's 60 pages, so I wouldn't advise printing it, but save it to your favorites list ;)
~Bethany~
Posted on Oct 05, 2008
We have a Rianni 1004F propane heater. We were wondering how low the temp will go in economy mode as we are leaving it on during the week while we are gone. The manual is unclear.
Do not leave it on. The thermostat could [ figuratively freeze up] lock on a certain temperature, overheat and cause internal wires to catch on fire
Nov 23, 2014 | Heating & Cooling
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Usually my rinnai 1004f is set at 64 and reads out about 66 or so. This morning I woke up and it read 48 and was freezing cold in my house. I tried cleaning out both filters and looking outside to make...
You can get any error code that may be stored by pressing on the Economy button and the UP and Down arrows all at the same time and hold for 5 or 6 seconds. This may get you a start on what may be the problem. Post them when you get them. If you do not get any error codes, remove the right side panel closest to the wall and look for a small black rubber bulb. That is the thermostat for the unit. If you hold it with your fingers, it should show a higher temp. I am afraid that you are going to need a technician who is familiar with Rinnai heaters if you can't get it going.
Jan 24, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai 1004F, no manual. Vent Contol Button is in open position, its winter, should vent be closed at all? Economy button, whats it for?
Not sure about Vent Control however the Economy button is like a night time set back. Over a 2 hour period it will decrease the temperature up to 6 degrees from set point. In morning, just take off economy and unit will come up to temp. Go to www.rinnai.us for on-line manual.
Nov 28, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How do i clean the filter in a rinnai energy saver 1004F
Here is a link to the users manual
http://www.rinnai.us/documentation/downloads/ES38_1004RFA_Manual.pdf
Check out page 10. As it shows the filter slide up from the top rear. Use a brush or vacuum cleaner.
Sep 16, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How to turn off the chid lock on a rinnai
The button to the left of the economy mode is the child lock button. Push it in and hold for one second to either activate or de-activate.
Jul 26, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
What part do i change when convertin a ranni propane gas to natural gas
I think the part numbers listed in the solution are LPG injectors.The orifices (injectors) needed to change over from Propane (LPG) to Gas (NAT.) would be 2 High Injectors 100F-2031-B-1.80 and one Low Injector 1004F-2036-B-1.95.
Feb 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
506 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
