Question about Panasonic Televison & Video
I have a Panasonic SA-PT750 and a new LCD HDTV (Sharp Aquos, 46"). The DVD quality is terrible. I changed the setting to 1080p on the DVD player but still not good. I am using an HDMI cable. Also, when playing a DVD the picture starts as 4:3 Letterbox which is long and thing but after a minute or so it changes to full screen which is terrible.
    Problem Solver:
  • 5 Answers
On tose new hdtvs youve gotta set screen format in the menu to manual,youve gotta do it when you watch dvds,, or else itll stay on full ,,and also under setup in the menu check to see if u have convirgence, most hdtvs have this. it realigns the colors. u have to set it for every input channel
Posted on Oct 05, 2008
NEED BASE STAND FOR A SHARP LC-46SV50U
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount.
Mar 30, 2013 | Sharp AQUOS LC-46SV50U 46" 1080p LCD TV -...
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Jul 24, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sound on my Aquos 46" 1080p LCD is intermittent as it comes on for 2 seconds and goes off for 2 seconds. I have checked all the connections and they are good. Any ideas??
1.The heat destroys the rubber between the chip and cooler.
The two chips faced down are touching the ground. Replace rubermaid heat transfer compound and youll be fine.
2. Resoldering the sound chip !!(need good experience and quality soldering equipment)
J
Dec 15, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Setting up sharp 46
Try to isolate the problem.
Try plugging in another source such as a DVD, is there audio? If yes, problem may be with the optimum box. If no, most likely a problem with the TV.
Also, if you are using HDMI with the HDTV box, make sure the box is set to output audio through HDMI.
Feb 10, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos
The screen resolution is determined by the source and not the television.  The source (e.g. a PlayStation 3) will query the television to determine which modes it is capable of and then (normally) use the highest available.
I've not had any problems with DVD players, computers, games consoles not managing to send 1080p so it might be worth checking the settings of the source device to see if there's anything you can change there.
Failing that I'd try and find a friend and borrow something from them that they know is working at 1080p without any problems - if the television still won't go to 1080p then its probably a fault in the HDMI cable or something odd with the television.
Nov 10, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
375 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
