Question about Epson Stylus 1400 InkJet Photo Printer
Feeding problem Feeds multiple sheets of paper at one time on a frequent basis.
  • 1 more comment
  • hartyhar Oct 05, 2008
    Epson model 1400 printer feeds multiple pages of paper at one time. Your suggested solution to fann the edges of the paper and reload comes from the printer's instruction manual to which we have already referred. This solution does not work for us. All five solutions sent through Professional paid assistance suggest the same solution which comes from the printer's instruction manual. Looking for another solution.
  • hartyhar Oct 06, 2008
    I have requested help on a feeding problem with my Epson 1400 printer. It feeds multiple pages about every other time it is used. Solutions suggested so far include flipping the corners of a stsck of papers to separate them which we have tried without luck as instructed by the owner's manual.
    The second suggestion is that the paper may have acquired moisture. This too,is not a solution as we live in a semi-desert climate at 6000 foot elevation and it is extremely dry here. However, have already tested to ensure this is not the case.
    Please continue with your proposed solutions. thanks
    We are using Epson Premium paper only.
    President:
  • 1,952 Answers
If you experience paper feeding problems, try loading fewer ... Epson Stylus Photo 1400. 1/07. Printing on CDs and DVDs. Your printer includes a special ... Stylus Photo 1400 - Product Information Guide','files.support.epson.com');">http://files.support.epson.com/pdf/pho140/pho140pg.pdf
read paper loading guidness
Posted on Oct 06, 2008
  • Epson Master
  • 1,879 Answers
Disconnect power.
clean the rollers that grab the paper with a swab dipped in lukewarm water.
let it dry.
about the paper you are using, refer to the manufacturer's recommendation (even with plain paper).
Posted on Oct 05, 2008
  • 1,031 Answers
All you need to do is run the printer a few times with no paper. While it's "printing", use a soft cloth and your index finger to clean the rubber wheel that pulls the paper through. The wheel is on the right side in the area where you feed the paper. do it several times and check for possible improvement
    Genius:
  • 1,689 Answers
Hi hartyhar , the quick start and the user guide of the device will give you a recommended paper type. you may also want to make sure that you are not using different types of paper in one set, like thin and thick at the same time...
  • marlon john madrid
    marlon john madrid Oct 06, 2008
    okay well if that is the case you may want to consider getting the rollers replaced because there is a possibility that they are worn out or derailed from its position...
    you can get OEM parts from Epson or from the store that carries epson hardwares.
    Genius:
  • 1,142 Answers
You need to change the paper reem as it might have been caught with moisture thats the reason its picking up multiple pages
  • 6,487 Answers
Remove all the paper from the sheet feeder , fan the edges to seperate the sheets and carefully reload it..
Hope that helps........
  • Mark Gil
    Mark Gil Oct 05, 2008
    If you already done those stspe the problem here is with the Pick Up Rollers that you may need to change it since it doesn't do what its should do...
    Brigadier General:
  • 3,614 Answers
HI THERE,
what is the exact printer model.?
for the moment try this few steps:
  1. Remove the photo paper from the photo tray.
  2. Place the photo paper in the photo tray.
    NOTE: Do not overload the photo tray. Load less paper into the tray to avoid paper jams.
  3. Make sure the paper length guide fits snugly against the edge of the photo paper.
    Guru:
  • 1,894 Answers
Give one paper and check if it accepts correctly
  • dewan nafees ahmed Oct 05, 2008
    this can be due to improper functioning of rollers which pull in the paper.
Printer feeding multiple pages
you need to cleaan the friction pad. it is under your paper where it picks up. or replace it.
Feb 06, 2014 | Samsung "scx-4623f multifunction laser...
Paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Apr 26, 2010 | HP LaserJet 6L Printer
Top paper feed does not feed 1 at a time, feeds multiple sheets or envelopes
Check for obstacles - top trays got biggest disadvantage: u may easily drop something into it. I`ve found 1GB memory card in mine
Dec 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Paper feed
Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
Dec 15, 2008 | HP OfficeJet Pro k550 Printer
Feeds multiple sheets of paper at once
This usually happens when "paper dust" builds up on the take in rollers. Clean the rollers with cotton and alcohol.
Sep 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Printer keeps jamming paper
without some information about the kind of printer and the weight/thickness of the paper, try to supply more information in a comment if you can, this is a generic answer.
many printers have a paper thickness adjustment that helps ensure that only one sheet is picked up at a time, and that the sheet feeds accurately,
if two or more sheets are picked up there are jams as multiple sheets do not feed well, and may not even get out of the paper tray. If the printer is set for a thicker paper, the lead edge of thinner sheets may miss its aimed path and wrap around guides or rollers, jamming.
The makers web page, or the user guide if you still have it, often have FAQ on paper jams,
Jul 02, 2008 | Office Equipment & Supplies
Paper feed problem
You need new feed components. Feed rollers and retard rollers or pads that stop multisheet feeds.
Dec 14, 2007 | Xerox DocuPrint N17 Laser Printer
Epson Stylus  1400 InkJet Photo Printer Logo
302 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
