Question about Samsung RS2630SH Side by Side Refrigerator
SAmsung rs2630sh how do I manually turn on my freezer defroster element?
  • 3 Answers
This modle is automatic you need not to defrost it if you have any ice formation broblemin freezerbdy there must be a door dagket gape plz check that
Posted on Oct 11, 2008
Why wont the freezer fan run on thesamsung?
maybe the defrost timer has the control wires going throu the timer which turns on the defrost elements, turns off the compressor, or door switch...
May 23, 2014 | Samsung RS2630SH Side by Side Refrigerator
Wont cool
The reason the doors get hot is to defrost its ok.
Jul 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
The freezer fan makes a very loud noise
it probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Apr 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Freezer side is fine. Fridge side says it is at
Samsung Refrigerators came with many different features. I need to be sure yours is the model RS2630SH If so I believe that defrost comes from the main control board on yours. You need to unplug and examine the freezer compartment behind the panel covering the evaporator. Looking over the wiring diagram the control comes from main board for the defrost element/heater to melt the ice on evaporator. If the evaporator is covered in ice you will need to defrost with a hair dryer and we will need to check the defrost heater with an ohm meter to make sure its OK first. If its OK then we need to visually look over the main control board for signs of heat or burn marks on both sides with power disconnected to the refrigerator. No defrost can cause this problem and the dampers from freezer if not opening properly will cause this. Let me know, Sea Breeze
Jun 22, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Jun 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge rs52530bwp the fridge side will not work
I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
The plastic inside the freezer is bubbled and looks like it has been on fire.
sounds like the defrost heating element has overheated...call a service repairman ASAP you may have a fire hazard on your home.
Mar 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
235 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
