Question about Pioneer PDP-5060HD 50 in. Plasma Television
Picture but no sound.
We have a picture but no sound. we have switched the cabels around to different inputs, and we can not get the sound to work.
    Genius:
  • 1,148 Answers
What about in the menu,,most the newer tvs have got were you can turn the speakers off,, or if there a digital dts plug on the back,, the menu could be switched to digital instead of analog,, good luck
Posted on Oct 05, 2008
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I've got a LG 42 inch HDTV model GP-DVB-EU When I
When you have just the cables as you describe, you are using composite inputs. By default, yellow is video, red is right audio, and white is left audio.
Nov 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
Jul 04, 2009 | Loewe Aconda ACO9303 30" TV
Sound stop working
Check sound on "Tuner" input. If still no audio, post a comment with your other equipment makes and models as well as cabeling and I can help some more.
Jun 28, 2009 | Onkyo HTR500 Receiver
My power windows on my 300te don't work, i bought it like this and also the fuse for my stereo just sizzles and blows up--i also need a diagram as to where the relays are supposed to go in order, i think...
i think i now whats wrong whit your stereo it sounds like one off the speaker cabeles or the power or grnd cabel is tuching metal some where in the car. check all the cabel on the stereo and se what you find
Jun 07, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Blue screen
It sounds like your kid switched to a different input. I am not sure what you have hooked up where but on your remote at the top there are two buttons - one is labeled HD.S and other is SD.S - I do not have my remote handy but am going from memory. The HD.S button switches to the hi-def inputs and the sd.s switches to the standard definition inputs. Try pressing these and switch around until you see a signal again. You will need to let the input "stabilize" and the picture appear so when you switch inputs give it 10 seconds or so before moving on.
Aug 06, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
DVI - HDMI cabel connection.
You must use a separate two wire audio cable with this connection.
Aug 02, 2008 | Televison & Video
RGB HD15 to Component/RCA cord
test with new cabels -and switch on your dvd first and projector second-confirm that projector input in video status(test with good brand cd).
Mar 12, 2008 | Eiki LC-XB20 Projector Multimedia...
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Pioneer PDP-5060HD 50 in. Plasma Television Logo
125 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
