Question about Frigidaire Refrigerators
The control lights and temperatures come on when we reset the fridge but then they immediately turn off-48" side by side refrigerator
  • 750 Answers
You said,
the control lights and temperatures come on when you reset the fridge but then they immediately turn off-48" side by side refrigerator.
You did the right thing if you unplugged the fridge for 5 minutes and then restarted it in order to reset it!
But if this did not work you now need an electronic diagnoses.
i wish there was something else I can do, But you are at that piont where you will need hands on service!
Thank you for allowing us to advise you!
Let me know how it goes!
Bless you, Huuum
Please remember to enter a rating for us.
Posted on Oct 05, 2008
Model MF12266AES French door fridge seems to be stuck in defrost mode. We were told there is a way to 'reboot' the system on the fridge (maybe by pressing the light button inside a number of times). Does...
Hello Jennifer
Here is my step by step instructions to follow.
1. Look inside your refrigerator and locate the temperature control switch. This is usually situated around the middle of the refrigerator's back panel. Some switches have a wheel mechanism, whereas others use digital displays.
2. Turn the temperature control wheel down to zero or switch to "Off" if you have a digital display.
3. Move your refrigerator away from the wall. Refrigerators are extremely heavy, so enlist the help of another person, if possible.
4. Unplug the refrigerator cord from the wall outlet. Leave unplugged for around two or three minutes.
5. Attach the power supply back to the wall outlet and position the refrigerator back against the wall. Your refrigerator temperature is now reset. Switch the temperature control back to "On" and adjust the temperature to the level required.
6. Open the ice making area of your refrigerator if it is producing watery ice cubes or an inconsistent water supply.
7. Locate the water filter status light inside the ice maker. This is usually a small rectangular light situated at the side of the ice maker.
8. Push the switch next to the status light seven or eight times in quick succession. This will reset your ice maker.
9. Check the status light. This should turn from red to green once the switch has been pressed several times. The green color indicates the ice maker has been reset.
Remember if you FRIDGE is on warranty you just send it first to the manufacturer.
Best Regards
Neciforo Llanto
Sep 21, 2013 | Refrigerators
How do you reset the display temperature
follow this steps and fix it. God bless you
    • 1
      Press the "Fridge" button on the refrigerator's front panel.
    • 2
      Press the "Fridge" button until there are more lights visible on the panel next to "Fridge" to set cooler temperatures.
    • 3
      Press the "Fridge" button until there are fewer lights visible on the panel next to "Fridge" to set warmer temperatures.
Read more: http://www.ehow.com/how_7696789_reset-temperature-samsung-refrigerator.html#ixzz2Ze3Som8U
Jul 21, 2013 | Samsung RS2630SH Side by Side Refrigerator
Over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Flashing lights
it takes a few miniute to turn on
Oct 16, 2008 | Kenmore 53092 / 53094 Side by Side...
Whirlpool gold refrigerator
YOUR FRIDGE DAMPER CONTROL COULD BE FAULTY IS TO THE TOP LEFT BACK OF THE FRIDGE COMPARTMENT.GOOD LUCK.MOHAMED
Sep 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Freezer cold, refrigerator not...
What make and model is your unit?
You may have a problem with the unit going into defrost, could be a defrost timer or a thermal fuse. Try defrosting your fridge for now but you may need a service call.
Look in you freezer for a manual control also, it will allow more air flow to the fridge section.
Sgt 48
Jun 02, 2008 | Roper Refrigerators
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
96 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
