Question about Kenmore 46462 Front Load Washer
46462 unit will not turn on
The washer will not power up . Even the lights on the display panel are not turning on . I have checked that the power outlet works .
  • anava214 Oct 05, 2008
    The washer is 14 months old . I have disconnected the cord but nothing happens.
  • 750 Answers
Hello anava214
Welcome
You said, your washer will not power up . Even the lights on the display panel are not turning on . And you have checked that the power outlet works.
Did you unplug the washer for 5 minutes and then plug it back in?
This can resets the system.
How old is the washer?
Posted on Oct 05, 2008
  • Neil Golan
    Neil Golan Oct 05, 2008
    Did you have the power off for 5 minutes or out and in?
    At 14 months and you are only 2 months past your warranty?
    It's a Kenmore?
    Go in person to the store and ask for the appliance manager.
    Ask him if he can do anything! HE CAN
    Tell him you are astounded by the poor quality of their product.
    That you have already picked out your Kenmore elite stainless steel kitchen
    And have the loan to remodel your kitchen,BUT you will not do so till they stand by their product!
    If he does not help, ask for the store manager!
    He can do what ever it takes to remedy the problem. HE HAS THE POWER!
    I do this for my customers sometimes when they do not know how!
    Just be sweet, friendly, and nice. No anger or emotion except for how wonderful they are to help you!
    SHMOOOOS them.
    This is the easy and cost free remedy. It Does Work.
    Today it's easier to keep the customers you have than to find new ones.
    Just be persistent and do not leave until you get satisfaction even if you sit down and tell them , "I'm not leaving!" "You can get me arrested at closing time but I'm not leaving!"
    Still being and talking very sweet and calm. This is the ticket!
    I promise you I HAVE DONE THIS!!!!!!!!!!!!!!
    Let me know how well it works. Huuum
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Dec 27, 2017 | Maytag Washing Machines
Amana front loading washer won't run after power outage. Panle does light up.
Possible that the program controller unit has failed if there is no display or power in the indication. You will need to remove panel to check on the fuse and if the new fuse fails it is possible there are error or hardware failure within the board.
Please remove and check the power panel for shorted drive, rectifier or capacitor, if not the panel must be replaced.
Jul 04, 2012 | Amana Washing Machines
Washer stops mid cycle and all lights flash and door is locked. no error code. We have to stop power off the washer turn power on and run through another full cycle
Reset the unit by unplugging for 40 minutes.
otherwise the ECU is at fault.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore 46462 Front Load Washer
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Mar 31, 2009 | Kenmore Washing Machines
Washing machine seems to quit at random and flashes F-01 messege. Seems like a control problem more than mechanical?
F01 - There may be an internal problem with the control, attempt a Hard Reset.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Mar 08, 2009 | Kenmore 46462 Front Load Washer
F01 and add a garment light on
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
Oct 13, 2008 | Kenmore 46462 Front Load Washer
F2 flashing on display screen washer won't continue cycle????
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Oct 12, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 powers off during spin cycle - no lights
i cleaned out the pump under the front bottom panel
Feb 03, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
268 people viewed this question
Sal De
fordexpert
Robert Rankin
