Question about Akai LCT3285TA 32 in. LCD Television
Sound has turned into a loud buzz
The sound on our big screen tv has turned into nothing but a loud buzz
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check,probably you change the sound module or if you can work efficiently on the module ,u change the sound ic & the entire electrolytic capacitor within the circuit.
Posted on Oct 05, 2008
Samsung Big screen mod. HL-P6163W made load pop, then buzzing sound with screen going to black and white. Make buzzing sound and no picture when turned back on?
This set has a problem with the color wheel falling apart, which if one of the segments should fly off while the set was on it may sound like a loud pop, and the buzzing sound could be mechanical in nature with the wheel being off balance. If smoke appeared after the loud pop, then it could be a capacitor blowing in the power or video circuits. This model uses two different types of Color Wheel assemblies, either an L3 or a L6 and it would be listed on a white label on the Light Engines metal frame. Hope your solution is this easy.
Bill
Mar 08, 2011 | Samsung HL-P6163W 61" TV
I have a hd61lpw165 big screen tv that makes a loud buzzing sound as soon a it goes on with no picture.
sounds like the lamp or ballast, check the lamp first to see if good, then if good, then probably the ballast is bad, but I think the sound or buzzing is coming from the ballast, so it's should be good.
Mar 04, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Picture and sound go after a while will come back after switching to standby Or the old fashion Bang on the top. Also a Loud buzzing sound in Standby.
U have tools like a soldering iron,a roll solders,also can u do basic soldering?Yes.This tv have cold solders joints in the(CRT-Tv tube) video board connections pins socket that connected to the(CRT-Tv tube).The tv loud buzzing sound is comming from the FBT-the flyback transformer,that is a big black block of plastic with a red wire with a cap that hook to the(CRT-Tv tube).Resolders both the FBT and the video board CRT socket holes connections.Will solved these 2 problems.
Dec 03, 2010 | Toshiba Televison & Video
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I turned on the DLPtv it made a weird sound and nothing happened.
Sounds like the High-voltage went out on the TV, probably have to replace TV
Aug 22, 2009 | RCA TruFlat 27F520T 27" TV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Hitachi c2114t loud buzz on bright screen
sounds like you have a gun or picture tube shorting. check the bottom of the tubes when you turn it on and see it one of them is lit up more then the other two if you find that then unplug the circut board thats pluged into the tube and turn on the tv again and see if you problem goes away minus that color.
Feb 23, 2008 | Televison & Video
Akai LCT3285TA 32 in. LCD Television Logo
112 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
