Hi Donald, Asko D3120 pump motor runs non stop. Pulling CB is the only way to stop it. The door control panel has no effect and does not seem to function properly. Thanks, Pete
Seems to be the fault with the control panel as it is possible that the drive relay stays triggered as soon as the power is switched on. All you need to is to remove the panel and check for a short in the power line output to the pump motor. Please check this link for tips to remove; Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html Use a multi-meter without which you will not be able to confirm the case. DO NOT BUY A NEW BOARD unless you have tested the board to confirm if the processor has failed or if this is a SCR or relay then it can be replaced.I would suggest that if there is a similar model with any contact or even from the service center where it can be swapped and tested or even tested on bench by simulation if you are familiar with the input connections.If none of the functions work then it is possible that the motherboard is faulty. Take estimate and decide.Compliments of the season.
