Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Replace heating element on a hotpoint bf162
Machine seems to run on cold so that grease is not dissolved and all didhes are wet. Suspect the element is blown - how can I replace it?
SOURCE:
yalmer
  • 552 Answers
SOURCE: BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Posted on Feb 09, 2008
  • 185 Answers
SOURCE: hotpoint bf162
after the 20 seconds does it restart
Posted on Mar 28, 2008
SOURCE: My Hotpoint WMA58 washing machine is not heating
We had this problem & called our repair man in. We had accidentally knocked the 'Variable Temperature' dial down too low. It should ALWAYS be set to max (95). The programmer will still sort out the correct temperatures for the different programmes, such as cold wash, but setting that to whatever temperature means that that is the max it will ever reach, Since then, we have not had that problem again.
Posted on Apr 04, 2009
vickygomar
  • 460 Answers
SOURCE: Want to replace the heating element
Can you tell me which one is your dishasher to better assist you.
HLD4040NSA
Hotpoint® Built-In Dishwasher
HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher
Thank you
Posted on May 15, 2009
  • 14 Answers
SOURCE: Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
Posted on May 18, 2009
On completion of cycle -dishes cold and v/wet.Tablet partially dissolved, dishes nearly clean!!
It is no longer heating the water. It could be a blown fuse on the heater circuit, or a failed temperature sensor, but more likely the heater element itself has failed.
Oct 17, 2015 | Dishwashers
Steam Boiler not heating up - pumps cold water but won't the boiler never heats up, I suspect the thermostat or solenoid
Check the 2 thermal fuses on the top of the boiler, if they are blown replace them and the thermostat. While you are at it replace the seals in the steam boiler, there are 5 of them in that boiler. If the fuses aren't blown check the element for continuity, sometimes one will fail.
Nov 27, 2013 | KitchenAid KPES100PM Espresso Machine
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Car sat for a while turn signal wont work but 4 way flashers do
common on olds make sure single contact bulbs & dobble contacts are in correct spots
and problem is in the front signals connecters remove bulbs and ull see burnt plastic
replace or clean
May 02, 2011 | 1994 Oldsmobile Cutlass Supreme
Hi i have a dwf30 for some reason all the items are coming out with lots of grease marks on them the tablet pops out ok as you can hear it but everything seems as if its not been rinsed out i thought it...
is there any strange rumbling or moaning coming from the drum ??? if so the oil and greace may be from the back bearing due to the bearing oil seal becoming faulty allowing water through to the bearings
Feb 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Clothes stink on top load model
Continually washing with cold water and liquid detergent can cause a buildup of undissolved detergent between the inner and outer tubs (unseen). This buildup of detergent feels like grease and will pick up dirt from each load and hold it on the grease surface. Over time...the dirt held in the greasy detergent can give off an odor.
This problem may be able to be cleared up by running many loads of hot water (to dissolve the detergent) with no clothes or detergent. Switching to powder detergent will also keep the liquid detergent gel from forming. If you like liquid I recommend using hot water for ALL your white loads. This should make every third or fourth load hot and help dissolve buildup from previous loads.
If you are not in the habit of using cold water and liquid detergent consider other sources of the odor. Some typical examples are sewer or septic backup through the drain and into the machine between the tubs where you can't see it. Also, the laundry is usually in the basement if you have one. The basement is the lowest part of the house drainage system and if you are developing a slow drain you may find some dirty water backing into the machine if it can't go down the drain quickly enough. Usually these drainage issues show up as a floor leak when you drain the washer in the spin cycles...but not always.
Good Luck.
Sep 17, 2009 | Kenmore Washing Machines
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Aug 29, 2009 | Frigidaire Dishwashers
Hotpoint dwt 10 dishwasher - the dishwasher tablet is not dissolving and remains in the bottom of the dishwasher after running a load therefore dishes arent cleaned!
I know it sounds strange, but many times when detergent dissolve, a failed heating element is to blame. The detergent needs that water to be hot to dissolve and activate the detergent.
Recommend you check the heating element for obvious damage/failure. When you run the full cycle, does the heating element get hot? If not, replacing it is not as hard as it appears. Post back here with further questions, OK?
If the heating element _is_ working, the other possibility is a failing wash pump motor, but depending on the age of your dishwasher, replacing
May 03, 2009 | Dishwashers
Our Westinghouse washing machine is 5 years old. it is not washing the grease, butter from cutlery. Also everything is wet. Do you know What is the cause? Thank you
It is almost certain that your heating element has failed and needs to be replaced.
The heating element must turn on to get the wash cycle water hot enough to activate the detergent.
Once the element is replaced, you will see immediate improvement.
Good Luck!
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
119 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
