Question about Electrolux Vacuums
Electrolux 720 Vacuum cleaner needs new cord retraction, spring cord & latch
4 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: Hi , I have replaced
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564353
Generic problem for all Vacuums
Hi, I have replaced
Posted by dryder on May 02, 2008
Hi, I have replaced the electric cord on Electrolux Lux Royal vacuum, but the rewind that retracts the cord does not pull it in. The coil spring looks ok but it will not pull the cord back in, any suggestions please.
Thanks Dave Ryder
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The question I have is it the Electrolux or the Royal cordwinder, if the cordwinder is sprung you may have to get a new one or a good used one, it’s been a while since I have done a cordwinder and I have seen it done, but I know when you remove the cordwinder you need to lock in the spring so that it does not loose it tension and re-coil ability. You may want to ask your local vac dealer to see if you need to repair or replace. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 02, 2008
  • 13 Answers
SOURCE: return cord on electrolux canister vacuum with bag purchased in 1969
Your machine should still be under warranty which is voided if you do the work yourself or have another vacuum shop do it for u.
Posted on Oct 03, 2008
  • 373 Answers
SOURCE: electrolux model 1401
try a local vacumn repair center or web site
Posted on Feb 04, 2009
SOURCE: electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Posted on Sep 02, 2009
How do you get into the rewinder?
This repair should be taken to a expert, If you take this cordwinder apart and don't know what you are doing you could end up having to replace the cordwinder because of the spring tensioner.
Jan 27, 2014 | Hoover Elite Rewind Bagless Upright...
Cord will not retract
Tilt the front of the vacuum to a 45-90 degree angle. Gently tug and release cord until it retracts.
If this doesn't work, repair or replacement of the cordwinder is needed. For this the vacuum needs to be taken to an authorized Aerus Electrolux store.
http://www.aerushome.com/storelocator/
Jan 31, 2011 | Electrolux Lux 5500 Canister Vacuum
Need to open the canister to get to the cord assembly of my Electrolux Lux 5000
Why do you need to get to the cord assembly?
If the cord will not retract, tilt the vacuum to about a 45 degree angle and gently tug and release cord. It will usually retract.
Due to problems ensuing from untrained persons attempting to reassemble the vacuum and having to take it to the shop anyway, I recommend not taking it apart.
If the above isn't the problem, please take it to the nearest Aerus Electrolux store for repair.
Jan 22, 2011 | Electrolux Lux 5500 Canister Vacuum
The cord won't retract, how do I fix it?
Hold the vacuum at a nearly upright position. Gently tug and release the cord near the vacuum. This should cause the cord to retract. If not, it may be a worn out spring or a broken piece on the cordwinder. If this is the case, it needs to be taken to an Aerus Electrolux store for repairs.
Jan 21, 2011 | Electrolux Vacuums
Model 720 vac the power cord will not retract
Lift the front of the vacuum so the canister is at about a 75 degree angle. Gently tug and release cord. It may take a few tries, but it usually works.
Jan 08, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux model 1401
Feb 04, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Hi , I have replaced the electric cord on Electrolux Lux Royal vacuum , but the rewind that retracts the cord does not pull it in . The coil spring looks ok but it will not pull the cord back in , any...
Hi, I have replaced
Thanks Dave Ryder
Customer Service
1-800-896-9756
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Automatic cord return
if it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
Aug 28, 2007 | Panasonic MC-V9644 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
29 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
