Question about Wacom Intuos3 Graphic Tablet
Help! Yellow note pad everywhre.
May I ask for help please with the yellow pad thing that is there permanently now? Drives me crazy that every time I try to draw with it now, this annoying yellow notepad comes flying out and I can't use the pen.
Billie
billie@spokanerainmaker.com
There is a program called Ink - you'll find it in your system preferences under the apple menu. You need to turn it off. This will allow you to use your wacom without that annoying yellow notepad everywhere!!
Posted on Oct 07, 2008
The yellow ink cartridge continues to not be recognized by my epson r1900 printer. I've tried numerous times to reset the cartridge and even tried a completely separate new yellow cartridge and the...
This might sound crazy but try this.
Switch the yellow and the magento cartridges out and try to print, it will error out again. Then switch them back to the proper slot. Try this first and it should work, if not, please reply back to me.
Jun 12, 2011 | Office Equipment & Supplies
What is a yellow circle with 3 dash lines on each side - 2000 VW Jetta
It's an yellow warning indicator lamp. It lights when brake pads are weared. Now it's time to replace weared brake pads!
Please do rate my response. Thanks!
Jan 22, 2011 | Volkswagen Jetta Cars & Trucks
What does it mean when the warning light to say the handbrake is on in a 3 series BMW turns yellow and stays permanently on?
This warning lights comes on when your brake pads or brake fluid is at the minimum marks. For your safety please control it the brake and fluid level.
Dec 17, 2010 | 2006 BMW 3 Series
Hi i got a 2000 mb mlk 320. the dash lights up when i turn the ignition with this symbol ( ) it goes on and off. there's nothing that says between in it like (ABS) or (!) so please help.
If light on yellow color I think It would be bark pads warning signal, please check brake pads not only outer inner too, because sensor fitted in inner pad some time outer pads not too bad but inner pads are worn, if not warn brake pads pssibly wiring faulty for brake pads sensors, if messege read color It would be low brake oil signal or hand brake signal, is this information helped you?
Oct 22, 2010 | 2002 Mercedes-Benz M-Class
My Sony Viao laptop DVD drive doesn't function! Please suggest a remedy to make it work. The solution posted, I couldnt comprehend, that was Please note that this works only with the Windows drivers....
1 Click on MY COMPUTER icon on the desktop. select properties on the pop menu. Select the device manager. All the drives loaded will be listed up. Select DVD drive and see there is no Yellow warning sign next to it. If there is no yellow sign click on this drive and click properties. You will find that it shows whether drive is working properly or not. In anycase you click on the update drive tab and wait for the action to complete. Then try playing DVD. If still there is no improvement go to support section in SONY web site and download the latest DVD drive for your model. Hopefully it should work now.
Dec 07, 2009 | Computers & Internet
Drum set for xbox 360 rock band 2
to sync: hit the sync button on the drum set and the xbox at the same time, you may have to hold the one on the set.
other problem: make sure you have good batteries in it, make sure the set is synced with the television, go into the freeplay mode under the drum trainer and do a drum roll on your yellow pad- if it skips some notes you either have to deal with the bad pads or you can send it in or get a new set all in all
Mar 16, 2009 | MTV Games Rock Band Bundle for Xbox 360
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Radio stay on after car turn off
Hi this is tech crazy
The solution to the problem you mentioned is as follows
just sounds like your ignition live to radio is actually permanant live.
Pull radio out and swap red and yellow over see if it helps. Is it an after market radio? If so this is probably the cause.
Hope this helps you a lot
Please do rate me on the above said solution
Feb 03, 2009 | JVC KD-G230 CD Player
Please help i need to reset the color
replace the convergence board about 100.00 for the board and you have to know what you are doing to remove the old one and put the new one in
Jun 23, 2008 | RCA P52926 52" Rear Projection Television
Treo 600
The problem with the screen pixels turning permanently yellow happened when the touchscreen have had a continuous pressure on it (destroying the licuid cristal display pixels; there is no repair other than touchscreen replacement. Regards, Mauricio mborja@interactive.net.ec
Jun 22, 2007 | Palm Treo 600 Handheld
Wacom Intuos3 Graphic Tablet Logo
1,852 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
